front tire question - Kawasaki Vulcan Forum : Vulcan Forums
 2Likes
post #1 of 17 (permalink) Old 05-31-2016, 11:14 AM Thread Starter
front tire question
So its a simple question . how has your guys front tired been wearing down? i seem to chew one up every season. and the tread dont even seem to ware down much. but the tire looses its structure and starts collapsing on its self. my assumption is that 1 being a 400lbs rider with a heavy bike puts accelerated ware on it while braking but still i wouldn't think id chew em up that fast. is this normal for any one else?
ramcharger is offline
post #2 of 17 (permalink) Old 05-31-2016, 06:05 PM
BOTM Winner
October 2016
V2K_Rod's Avatar
Might want to consider doing double dark. Rear tire up front with rotation arrow backwards. I ran a Pireli 150/80-16 rear up front for years and weigh in at 290#. Plenty of thread left, but went to an HD 130 wheel up front.
Sent from my SAMSUNG-SGH-I537 using Tapatalk
Silencer69 likes this.
V2K_Rod is offline
post #3 of 17 (permalink) Old 06-01-2016, 05:13 AM
What brand and size tyre? How many miles?
Kwaka 2ltr is offline
post #4 of 17 (permalink) Old 06-01-2016, 07:44 AM
bigblockyeti's Avatar
Year/Make/Model: 2008 V2KLT
My stock front bridgestone is cupped pretty bad and howls like crazy just off a straight line, less so with a little more lean. Dead straight has gotten a little noisy but not too bad. The only scary thing about having it cup the way it has it the propensity for the bars to shake a little while slowing through 30mph or so. It still sticks in corners and stops well despite the cupping problem. The rear tire is down to the bars and a replacement for both is in the garage waiting to be levered on and balanced up, time is forever escaping me and I've put less than 200 miles on the odo so far this year.
bigblockyeti is offline
post #5 of 17 (permalink) Old 06-01-2016, 09:14 AM
Silencer69's Avatar
Year/Make/Model: 2005 kawasaki Vulcan 2000 limited
Displacement/CC's: 2053
Color: Red/Black ("Black Cherry")
I'm using the same double dark method as Rod, but with a Metzler 150/80 rear on backwards.
Silencer69 is offline
post #6 of 17 (permalink) Old 06-01-2016, 10:42 AM Thread Starter
glad you brought that up. when i bought the bike it had a night dragon on the front and after looking at the tread it was a rear night dragon as well. i might do that again. that tire took some real abuse. and it even split on me and i was still able to limp it home 350+ miles after if had a 3 inch by 1cm crack down the center.
post #7 of 17 (permalink) Old 06-02-2016, 03:49 AM
I had Bridgestones om ,mine for a while and loved them. I only went to Avons to see if I would get better wear, and,,, just to try them.
Being a,,, larger rider, it sounds like maybe your tyre pressures are too low. I run 36lb as a 91kg rider. I would think at less 38lb pressure for you, if not a tad more. I loaded my bike up and put up 2 1/2 thousand miles on her, but did not up the pressure enough. The rear tyre cupped big time. No problems now, since I up the pressure when loaded. 2 thousand miles around Tasmania at Xmas and no problems with unusual wear, with 44lb in the rear tyre, 38lb in the front.
Enjoy
post #8 of 17 (permalink) Old 06-02-2016, 03:45 PM Thread Starter
i normally run about -30-35 in the read but i have a car tire on the rear and front i run 35-40 i think closer to 35. i need to check i havnt since the start of winter. i was really impressed with how long the night dragon held up. considering its damage. i might seem about doing this again. so whats the deal with the rotation arrows pointing backwards? whats that do ?
post #9 of 17 (permalink) Old 06-02-2016, 07:00 PM
Year/Make/Model: 2003 Kawasaki VN2000
Color: Burgundy
What does tire cupping means? I don't understand it. I appreciate an explanation or a photo of the ware pattern.
My concern is my bike has 8200 miles on the clock with the original OEM rear tire Bridgestone. The front has been changed by the original owner but not the back one.
The tire looks to be in ok condition with a bit of ware but still have tread on it and could go another 1000 miles or so. I am worried because most of the posters talks about 6000 miles life of the tire.
I am 215 lbs 6'-1" and always have the tires around 40 psi cold. Use both brakes front and rare gently.
VN Pilot is offline
post #10 of 17 (permalink) Old 06-03-2016, 12:46 PM Thread Starter
cupping is basically the tire loosing its structure integrity. the tires rubber had "dents" in it or a "cup" shape. when i finally changed my 1st front tire i had a crack down the center of it and about 6-7 golf ball size dents staggered through out the tire. you notice this big time when it starts getting bad. perhaps not as fast on the rear but the front you will get a real nasty vibration in your whole front in and a death wobble will develop.
also ive heard people refer to this type of ware as cupping but also called having a band collapse. there will be a ring that goes all the way around your tire where part of it is indented so your whole tire looks slightly lop sided. once the tire wares down you start to notice this defect more and more because you will get a flat spot to one side of your tire rather then in the center of it like normal ware would do.
VN Pilot likes this.
Front tire pressure question? budda109 Vulcan 2000 6 06-25-2018 10:55 PM
Tire Pressure Question - Which One is Right? / Preload Adjustment Question BobinNC Vulcan 900 12 05-11-2018 11:32 AM
Front tire question nascarguy67 Vulcan 1600 4 05-10-2015 03:39 AM
Tire upgrade same rim different size tire 230/60B15 BlackedOutVulcan Vulcan 900 0 08-03-2010 02:56 PM
Tubeless tire vs. tube tire dpmooretn Wheels and Tires 3 07-30-2009 01:08 PM
