Neutral light isn't coming on, won't start with stand down. - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 17 (permalink) Old 04-10-2014, 09:59 AM Thread Starter
This morning, I started having problems with my neutral light.
I always put the bike in neutral, start it, and walk away to let it warm up for a little, but this time, the neutral light was not coming on.
I tried pressing up on the lever a bit harder, and there are some spots where the light does come on, but as soon as I let go of the shift lever, the light goes off again.
So at least I know the bulb itself is good.
Any idea what could be going wrong?
I appreciate your help guys...and sorry if this has been asked before.
Texas_Jack is offline
post #2 of 17 (permalink) Old 04-10-2014, 10:32 AM
SWVA_08V2k's Avatar
I never looked in to it a lot, but I have had that happen to me a few times on my 08. But if i rock the bike back and forth a few times and kit in between 1st and neutral a few times it comes back on. Just never thought much of it personally. Curious as to what I may see here though.
SWVA_08V2k is offline
post #3 of 17 (permalink) Old 04-10-2014, 11:51 AM
smedlin's Avatar
yea, do like 08V2K said, rock the bike just a bit to change up the clutch plates some.
Also, your oil condition/type can have a huge affect on that as well (it's a wet clutch, and it uses the same oil as your engine oil..)
Yes, I'm a Chrome Whore.
2004 Vulcan 2000
smedlin is online now
post #4 of 17 (permalink) Old 04-10-2014, 01:00 PM
I recently had my gear position sensor or Neutral switch replaced because it was failing. Now it works about 70% of the time. I called the shop, and they told me that there was also a pin and a spring that they should have replaced, and they ordered the parts to do that. I'll let you know if / when they get it in and get replaced and we'll see if that fixes it. In the meantime, I also found that rocking the bike seems to help.
BigT is offline
post #5 of 17 (permalink) Old 04-10-2014, 01:06 PM
davidr's Avatar
Sounds like the gear position switch is going bad. You have to remove the transmission cover to get to it.
BigT beat me to it. I got a phone call in the middle of typing.
BigT, are they going to charge you to go back in since they should have replaced the parts to begin with?
2007 V2K, Pearl White/Ti, Road Burner 3", Fi2000, Euro gears, Double Darkside (totaled 4/25/15)
1998 STX 1100 JETSKI (HERS)
1996 ZXi 1100 JETSKI
1990 KDX200
1982 GL500 SILVERWING (sold)
1981 KDX175
1983 JEEP WAGONEER
davidr is offline
post #6 of 17 (permalink) Old 04-10-2014, 01:38 PM
You can stretch the spring yourself and save the money on any replacement parts. Now with that being said, its a small spring and doesnt need to be pulled straight, increase the length of it uncompressed by 25% and that should be more than sufficiant.
1996 VN1500 classic-28K miles Sold and missed :'-(
2005 VN2000-12.5K miles
midwest_motorhead is offline
post #7 of 17 (permalink) Old 04-10-2014, 01:39 PM Thread Starter
Thanks for the info guys. Yeah, some rocking helped. I parked it on my driveway, which is in a slight upward incline, and the light went on at first. I went for a short ride again, and then once I parked later, the light flickered a little, then went off.
Thanks BigT, I'll await your reply, to see if I need to replace that.
post #8 of 17 (permalink) Old 04-10-2014, 03:10 PM
Davidr: no, they're not going to charge me labor. If so, I think I'd have pulled the cover and stretched the spring or replaced the part myself! Now that I've had her a couple of weeks, I'm markedly more comfortable with what noises she's SUPPOSED to be making, and not nearly as concerned about dragging out the tool kits. LOL.
BigT is offline
post #9 of 17 (permalink) Old 04-10-2014, 04:18 PM
wocka, wocka, wocka
Poncho Villa's Avatar
Originally Posted by Texas_Jack View Post
Thanks for the info guys. Yeah, some rocking helped. I parked it on my driveway, which is in a slight upward incline, and the light went on at first. I went for a short ride again, and then once I parked later, the light flickered a little, then went off. Thanks BigT, I'll await your reply, to see if I need to replace that.
tj, look at the eurogear threads and see a pic of the gear position sensor/brass pin under the right side gear box cover. its that little brass pin (spring loaded) in the hex shaped doohiky under the gears.. somebody has a pic.pdf can post it here for the troops to see.
Poncho Villa is offline
post #10 of 17 (permalink) Old 04-10-2014, 08:48 PM
DESERT ANGEL's Avatar
my 04 would not crank after a fuel stop in AZ the neutral light would not come on after fooling around with for a while I found out it would crank and start if I pulled the clutch all the way in
drove it that way for about 3 months
took it to dealer they replaced the gear position sensor for about 400.00 been good since then
DESERT ANGEL is offline
won't stay on in neutral with kickstand down usn09AV Vulcan 1500 11 11-26-2016 02:30 PM
Won't start unless in neutral crrider Vulcan 900 17 07-18-2014 06:00 PM
Bike Won't Start, if it does, won't idle xantonin Vulcan 500 17 10-06-2012 07:49 PM
Bike Won't START, clicks won't turn over. jimartina Vulcan 800 44 04-27-2011 04:17 PM
bike won t start until it cools down obumer Vulcan 1600 20 04-28-2010 06:48 AM
