Another Starting Problem - Kawasaki Vulcan Forum : Vulcan Forums
 4Likes
  • 1 Post By vulcandoc
  • 3 Post By Madmatt54
post #1 of 7 (permalink) Old 07-12-2019, 09:41 AM Thread Starter
Madmatt54's Avatar
Year/Make/Model: 2015 Kawasaki VulcanS
Displacement/CC's: 650
Color: Black and Green
I've recently changed the battery after having issues with the bike starting. I got up this morning to ride and nothing. When I turn the key, everything lights up, but I do not hear the fuel pump priming. When I hit the starter button, nothing happens. I tried jumping it across the solenoid and it will turn over that way quite well, but it will not fire. I tried changing the solenoid and checked all the fuses. Nothing will make the fuel pump engage, or the bike try to fire. I'm now out of ideas on what to try.
Madmatt54 is offline
post #2 of 7 (permalink) Old 07-12-2019, 11:58 AM
alliswell's Avatar
Year/Make/Model: 2015 Vulcan S
Color: Ebony
side stand sensor? have you tried it in neutral with the side stand up?
SOTGATTATGSOTT
(some of the gear all the time, all the gear some of the time)
alliswell is offline
post #3 of 7 (permalink) Old 07-12-2019, 01:07 PM
Color: Black / grey
Right hand handlebar cut off switch in right position???
TOMB likes this.
vulcandoc is offline
post #4 of 7 (permalink) Old 07-12-2019, 02:03 PM
Year/Make/Model: 2019 Kawasaki Vulcan S ABS
Color: Matte Green
If your starter button does not work I bet it's all tied together with the circuit that controls the fuel pump. Maybe it's a computer issue? You have two different problems:
- When you turn on the key the fuel pump does not prime
- Your starter button does not work
Sounds like the side stand switch "alliswell" or maybe the kill switch "vulcandoc". Or, maybe your battery voltage is too low? Bad connection on the battery?
- Check your battery connections
- Put up the side stand
- Pull in the clutch
Maybe hook up a battery charger (not trickle charge) or jump it?
jdocster is offline
post #5 of 7 (permalink) Old 07-12-2019, 02:12 PM Thread Starter
Madmatt54's Avatar
I feel like an idiot, because it was the cutoff switch. I never use it though, so I don't think about it. I also thought it would cut all power not just the ignition.
longbeachgary, TOMB and jdocster like this.
post #6 of 7 (permalink) Old 07-12-2019, 07:54 PM
alliswell's Avatar
Color: Ebony
no worries, glad it was an easy fix.
SOTGATTATGSOTT
post #7 of 7 (permalink) Old 07-13-2019, 05:04 AM
SuperHappyFunTime's Avatar
LOL. Cheapest repair EVER!
SuperHappyFunTime is offline
