2019 vulcan s speedo not corrected - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 13 (permalink) Old 04-14-2019, 08:48 PM Thread Starter
Year/Make/Model: 2019 Kawasaki Vulcan s
Displacement/CC's: 650
Color: matte black
Hi all. just bought the bike in March, I have put a 1000km thus far. My speedometer is out 5 % on the fast side, so I have to add 5% to my speedometer reading to drive at the desired speed, for example, if I want to do 60 I have my speedo has to read 63. I thought it would be an easy fix, I'll change the rear sprocket and drop about 3 teeth. so I did, I went from the stock 46 tooth to a 43 took a couple of links out of the chain, everything went smooth until I drove it with my GPS. I was thinking the 2 would be fairly close but to my surprise, the speedo is out 5 % it did not change the speedo at all. the only thing that would make sense to me is the speed sensor is getting its reading from the rear ABS sensor. everything I've read says if you change your gear you change your speedometer. back to looking at a speedo healer, I guess. wonder when they mad the change?
frogmelester is offline
post #2 of 13 (permalink) Old 04-14-2019, 08:54 PM
Tbachli's Avatar
Year/Make/Model: 2018 Vulcan S
Color: White
Putting extra miles on the bike too, I'd look at a recalibration if possible. Warranty issue?
2018 Vulcan S ABS
Booster plug
12V outlet (no relay)
Kawi soft tail bag
Madstad 18" shield
Puig eng guards
Tbachli is online now
post #3 of 13 (permalink) Old 04-14-2019, 09:00 PM Thread Starter
Color: matte black
the industry standard is plus or minus 5 %, so the warranty won't touch it. it is within an acceptable range
post #4 of 13 (permalink) Old 04-14-2019, 09:26 PM
JoeHollywood's Avatar
Year/Make/Model: 2017 Vulcan S
There’s a regulation that allows the speedo to be too fast by as much as... 10%, I think, but it can never read under. For that reason, to make sure they never run under, most motorcycle speedometers run high. But if you check the odometer by the GPS, you might find it to be accurate.
JoeHollywood is online now
post #5 of 13 (permalink) Old 04-15-2019, 12:00 AM
metzroth's Avatar
Year/Make/Model: 2016 Kawasaki Vulcan S ABS Cafe
Color: Black/Green/Silver
I find mine is fast by 3 mph as well. I had a radar thingy near my house for a while.... Nissan Leaf 0.5 mph over, Chevy Volt 1.5 over, Vulcan S 2.5 over. None of them under :-)
metzroth is online now
post #6 of 13 (permalink) Old 04-15-2019, 10:23 AM
JD Hog's Avatar
Year/Make/Model: 2015 Vulcan Voyager
Color: Metallic Carbon Gray/Metallic Spark Black
On my Voyager my speedometer reads faster but the odometer reads exact to my Garmin Zumo. 150 miles on the trip meter and 150 on the Garmin fuel mileage app.
Jim Diebolt
2015 Vulcan 1700 Voyager ABS
"The Black Kaw"
JD Hog is offline
post #7 of 13 (permalink) Old 04-15-2019, 12:25 PM
rangemaster728's Avatar
Year/Make/Model: 2016/Kawasaki/Vulcan S ABS
Displacement/CC's: 649
Color: Urban White
Speed calculation is typically taken from the ABS ring/sensor system on most modern bikes...not from an RPM/gear ratio calculation. This is why a sprocket change will usually not result in an indicated speed difference if you add/reduce sprocket teeth.
Electrical Engineer
2014 HD FLHTK
2013 BMW K1600GTL
2016 Vulcan S ABS
rangemaster728 is offline
post #8 of 13 (permalink) Old 04-15-2019, 02:50 PM
MARINE's Avatar
Year/Make/Model: 2016 Kawaski Vulcan S ABS SE
Displacement/CC's: 649cc
Color: Blue
My 2016 is off by about 5 mph. When im.doing let's 60 it's really 55. Pretty common for these bikes. Just go 5 mph faster 🙂
MARINE is offline
post #9 of 13 (permalink) Old 04-15-2019, 03:21 PM
Color: Black / grey
This is a dead horse.
All bikes since the "beginning of time" have had this.
Its a Googleable - is that a word? - thing!
1995 en500 stock with windshield - 29,000 miles
vulcandoc is offline
post #10 of 13 (permalink) Old 04-15-2019, 07:28 PM
bearslayer's Avatar
Year/Make/Model: 2004 Nomad , 1985 BMW K100 X2 , 1985 Intruder, 1998 Ducati Monster, 1972 CL350, 1948 Indian CZ125, 2
Displacement/CC's: 125 -1500
Color: Blue & Silver , Black , Gray , Maroon,black,
I have a 2016 when I changed from the 46 to a 43 It put it dead on. however since someone pointed pout that the speedo has changed the pickup location guess you will have to go with one of those calibration units. But really don't you think that the smoothness was worth the sprocket change?
That which does not kill me tends to really piss me off.
bearslayer is online now
Speedo Problems Don Ciccio General Vulcan Talk 1 05-18-2013 04:47 PM
Speedo Problems Don Ciccio New Member Introductions 4 04-24-2013 06:22 AM
Speedo Gear A vs C on an A Wheel Beelzebub Vulcan 500 1 01-19-2013 07:35 AM
Nomad speedo failure - more Gershwin Vulcan 1500 3 06-03-2012 06:38 AM
Speedo needle began jumping around this morning... have you experienced this? Mambo Dave Vulcan 800 19 06-26-2011 04:41 PM
