Couldnt get my oil filter open.. (again) - Page 3 - Kawasaki Vulcan Forum : Vulcan Forums
 3Likes
post #21 of 31 (permalink) Old 04-17-2019, 11:20 AM
1barron's Avatar
Cool
Originally Posted by MrCow View Post
So.. My first try was about 600km ago.
I wanted to try again so i bought this filter wrench from amazon. Turn out its too damn big.
I tried to stick a wrench through the filter but it wouldnt move at all. Im not sure what kind of gorilia installed my oil filter but it just wont get out.
Any solutions? Since right now my bike is empty from oil
Sent from my ONEPLUS A5000 using Tapatalk
If you are in a hurry try the following, ! if your current wrench is too large try cutting up an old intertube and place it in your wrench to make it fir. 2. get the type of wrench that tightens as you turn it 3. buy or bower a large "Slip Joint Plyers.". If none of the above work you may want to, as a last resort only, Punch a screw driver through the filter. I do not recommend this method. You could also search YouTube for a solution.
Good Luck
1600 Mean Streak
“Not all those who wander are lost.” Tolkien
1barron is offline
post #22 of 31 (permalink) Old 04-17-2019, 11:22 AM Thread Starter
MrCow's Avatar
Year/Make/Model: Vulcan S 2017 ABS
Displacement/CC's: 650
Color: Matt Black
Good Luck
I mentioned that i tried a lot of methods but that damn filter was too tight
Ended up buying a strap wrench (which i had doubts it will even work)
I got that sucker out
Um...Moo?
MrCow is offline
post #23 of 31 (permalink) Old 04-18-2019, 11:09 AM
Year/Make/Model: 17 Kawasaki Vulcan S
Color: Green / white
Not sure if anyone else recommended but the K&N-303 oil filter is awesome. It has a nut welded on the end so you can remove it with a wrench / socket. It is so easy. The oil filter can be bought on Amazon too!
Mattty is offline
post #24 of 31 (permalink) Old 04-18-2019, 11:19 AM Thread Starter
MrCow's Avatar
Color: Matt Black
I actually heared that some people got a faulty filter so i got a HF filter instead
Um...Moo?
MrCow is offline
post #25 of 31 (permalink) Old 04-18-2019, 11:53 AM
If you can't unscrew the filter using just your hand, you're putting them on too tight.
VulcanDrifter is offline
post #26 of 31 (permalink) Old 04-18-2019, 12:17 PM
whoaru99's Avatar
Dunno if I necessarily agree 100% with that but, generally, as long as it doesn't leak I'd think that constitutes tight enough.
I only change mine once per year (which is consistent with miles driven and recommended service interval - one year always comes first) so even hand tight at install I doubt it would come off by hand later.
whoaru99 is offline
post #27 of 31 (permalink) Old 04-18-2019, 02:12 PM
B3Hulk's Avatar
There is a cheaper alternative that has the nut welded ,I use the RP303 and I bought them in bulk. Direct Equivilent to KN303 or HF303
RP303 does its job , never leaked on me and is cheap
Check out my build :
B3Hulk is online now
post #28 of 31 (permalink) Old 04-18-2019, 02:15 PM
VulcanHead's Avatar
I'm pretty sure I read somewhere Hiflofiltro makes the filters for K&N. If you look at their racing filter, its pretty much identical, with nut and all.
VulcanHead is offline
post #29 of 31 (permalink) Old 04-18-2019, 03:50 PM
bearslayer's Avatar
Year/Make/Model: 2004 Nomad , 1985 BMW K100 X2 , 1985 Intruder, 1998 Ducati Monster, 1972 CL350, 1948 Indian CZ125, 2
Displacement/CC's: 125 -1500
Color: Blue & Silver , Black , Gray , Maroon,black,
This one has never failed for me
Name:	e98a7b36-f515-4dfa-ad27-09b32d4d1d8a_1_1555620628692.5fea8c3d4ab7adba73e6118c5c7eb0f7.jpg
That which does not kill me tends to really piss me off.
bearslayer is offline
post #30 of 31 (permalink) Old 04-18-2019, 03:52 PM
bearslayer's Avatar
Wix, Mobil, or Purolator. No handy nut but great filters
2011 Vulcan 1700 Classic stalling problem mcfan50 Vulcan 1700 21 08-09-2016 10:17 PM
burped oil filter... all over me Idahoser Vulcan 500 20 06-08-2014 08:17 PM
2011 an up Stalling issues? Kaz71 Vulcan 1700 33 09-10-2013 08:45 PM
First oil change milleage? evodog Vulcan 900 40 09-18-2012 03:48 PM
K&P Engineering's Reusable Oil Filter admin Vulcan Forums News 1 04-24-2008 11:42 PM
