Tire Question - Page 4 - Kawasaki Vulcan Forum : Vulcan Forums
 17Likes
post #31 of 64 (permalink) Old 09-06-2018, 08:51 AM
KeepRidin's Avatar
Year/Make/Model: 2015 Kawasaki Vulcan S
Displacement/CC's: 649 cc
Color: Green
These are the stems I replaced with.
90 Degree CNC Motorcycle Valve Stems Tire 10mm Pair 11.3mm Rim Wheel Aluminum (Black)
KeepRidin is offline
post #32 of 64 (permalink) Old 09-06-2018, 09:17 AM
texasnurse's Avatar
Year/Make/Model: (SOLD) Kawasaki Vulcan S [Harley-Davidson FLXTRS Road Glide Special]
Displacement/CC's: 107 (1746cc)
Color: Bonneville Salt Pearl
Tire Question
Originally Posted by ChrisHead View Post
What size rubber valve stem does our beloved Vulcan S use?
Same on front and rear?
If I'm going to replace them I will need to get the right ones and unfortunately if the info is in the service manual I didn't see it and I'm at work now so not in position to check. And just in case I can't work out timing with @texasnurse this morning I may go ahead and order from Amazon...but before I do that I need confidence I'm ordering the right size.
Looking at Bikemaster I see they have 10mm and 15mm rubber valve stems. Interestingly they have two different 10MM stems, the TR412 and TR413, but I don't see any explanation of the difference between the two on their site. As well, their 15mm stem is also labels TR412. I am confused...LOL!!
Finding a stem puller isn't nearly so complicated but if I'm going to the route of replacing the entire valve stem I damn well need the right one.
Who knows the answer?
Tr412 is the factory stem
Saddle up and feel the wind in your Helmet! ATGATT
ChrisHead likes this.
texasnurse is offline
post #33 of 64 (permalink) Old 09-06-2018, 09:18 AM Thread Starter
ChrisHead's Avatar
Year/Make/Model: 2016 Kawasaki Vulcan S Cafe 2018 Kawasaki Z900RS
Cool...I'd probably go with something like that if I didn't already have 90 degree attachments. But very good for those that haven't done gone to 90 degrees yet...makes it MUCH easier to check your pressure and add PSI.
Question I have is that while the product description says "10mm" all of the other references say "11.3mm" which leaves me wondering if 10mm stems would be the right choice or if I need to search for 11.3mm now.
@KeepRidin - Am I correct then that these unscrew for install and you screw the base back on once it's threaded through the hole in the rim? As opposed to the rubber stems that get pulled through the hole in order to seat in the opening.
As I think about it while typing this, since my son just got a used starter bike I could replace my stems with something these and just give my 90 degree extensions to him. Please let me know about these aluminum stems and how they're installed.
I'm trying to decide what to do and communicate with @texasnurse in time to make a decision today and order/ship what I need today so I can knock this out in time to get some riding done this weekend.
Thanks,
Chris
Living the dream!!
ChrisHead is offline
post #34 of 64 (permalink) Old 09-06-2018, 11:15 AM
KeepRidin's Avatar
Color: Green
@ChrisHead You are correct on install. I put a dab of locktite on the threads just to be safe. I was worried about leaks around the stem at first but 6 months later I haven't had to add a single PSI, so I think we're good. There is enough space inside the wheel to get a socket on the nut, and I used a decent set of channel locks with a rag to hold the stem side.
I wish I would've measured these before install as the product description is very confusing, I just hoped for the best and was glad it worked, lol.
post #35 of 64 (permalink) Old 09-06-2018, 12:43 PM
IndyTom's Avatar
Year/Make/Model: 2016 Kawasaki Vulcan S Cafe ABS
Displacement/CC's: 650
Color: Matte Gray/Green
I wonder if those angle valves mess with your wheel balance? I am sure the wheels would have to be balanced once they are installed. So far I haven't had any major issues checking my tire pressure or putting some air in with the regular valves installed.
IndyTom is offline
post #36 of 64 (permalink) Old 09-06-2018, 01:41 PM
KeepRidin's Avatar
Color: Green
Both tires I mounted with these 90 stems needed weights opposite the stem (no surprise really) but didn't need more the the factory tolerance stated in the service manual.
-KeepRidin
post #37 of 64 (permalink) Old 09-06-2018, 02:14 PM
Sapro's Avatar
Year/Make/Model: 2015 Vulcan S
Color: Black, like my soul
90 Degree CNC Motorcycle Valve Stems Tire 10mm Pair 11.3mm Rim Wheel Aluminum (Black) https://www.amazon.com/dp/B01K1WN6JI..._FctKBb2P15K38
Nice, I even like the color
KeepRidin likes this.
Sapro is offline
post #38 of 64 (permalink) Old 09-06-2018, 03:38 PM
bearslayer's Avatar
Year/Make/Model: 2004 Nomad , 1985 BMW K100 X2 , 1985 Intruder, 1998 Ducati Monster, 1972 CL350, 1948 Indian CZ125, 2
Displacement/CC's: 125 -1500
Color: Blue & Silver , Black , Gray , Maroon,black,
Cool Ummmm
And another advantage of balancing beads. . I put them on all my scooters. Now if I just remembered to have them facing right so I could reach them easier,
the ceramic beads ( or Ride On ) makes it a plug and play event.
https://www.ride-on.com/
That which does not kill me tends to really piss me off.
bearslayer is offline
post #39 of 64 (permalink) Old 09-06-2018, 04:12 PM
texasnurse's Avatar
https://www.youtube.com/watch?v=w8b6eqde_5A
Also makes the tire impossible to Plug
post #40 of 64 (permalink) Old 09-07-2018, 01:32 AM
bearslayer's Avatar
With Ride On there's no need to plug. And the ceramic beads have not interfered when I used a plug. .
Tire Pressure Question - Which One is Right? / Preload Adjustment Question BobinNC Vulcan 900 12 05-11-2018 11:32 AM
230 tire with the 240 fat tire Fender NorThai Vulcan 900 5 04-28-2011 08:19 AM
Tire upgrade same rim different size tire 230/60B15 BlackedOutVulcan Vulcan 900 0 08-03-2010 02:56 PM
Tubeless tire vs. tube tire dpmooretn Wheels and Tires 3 07-30-2009 01:08 PM
