Tire Question - Page 3 - Kawasaki Vulcan Forum : Vulcan Forums
 17Likes
post #21 of 64 (permalink) Old 09-04-2018, 03:34 AM
texasnurse's Avatar
Year/Make/Model: (SOLD) Kawasaki Vulcan S [Harley-Davidson FLXTRS Road Glide Special]
Displacement/CC's: 107 (1746cc)
Color: Bonneville Salt Pearl
Originally Posted by Synycalwon View Post
Was just cleaning and putting my bike away for the day and saw the black strip of stick on wheel weights (inside edge of wheel) the dealer has been putting on (believe the stock ones were just metal clip-ons to the center of the wheel). It got me thinking, for those that replace your own tires how do you balance them?
Read the reviews on the MP stand before you buy; I have a bike master .
The rest of the products used work.
Saddle up and feel the wind in your Helmet! ATGATT
KeepRidin likes this.
texasnurse is offline
post #22 of 64 (permalink) Old 09-04-2018, 12:47 PM Thread Starter
ChrisHead's Avatar
Year/Make/Model: 2016 Kawasaki Vulcan S Cafe 2018 Kawasaki Z900RS
@texasnurse - Yes, I ordered both rear and front tires as well as fork lift to get the the front end off the ground. After the responses above and some research it was clearly the way to go.
@Synycalwon - As @KeepRidin stated you'll need a balancing stand which I ordered. From the videos I watched it's an easy process provided you have the appropriate tools to execute it properly which in this case is basically a quality stand and the necessary weights to balance the wheel. Not to mention all the tools needed to remove the wheels, get the old tires off, new ones on, etc.
All in all though from the videos I watched it seems a relatively straightforward activity and one that may seem like a big challenge at first but, like of maintenance activities, after you do it once it won't be nearly as daunting. At least that's what I keep telling myself...lol
Chris
Living the dream!!
ChrisHead is offline
post #23 of 64 (permalink) Old 09-04-2018, 06:06 PM
bearslayer's Avatar
Year/Make/Model: 2004 Nomad , 1985 BMW K100 X2 , 1985 Intruder, 1998 Ducati Monster, 1972 CL350, 1948 Indian CZ125, 2
Displacement/CC's: 125 -1500
Color: Blue & Silver , Black , Gray , Maroon,black,
Cool Actually
Chris[/QUOTE]
Well I have a balancer but no longer use it. Started using the ceramic beads about 4 years ago and have NO complaints. I intend to try Ride On next time.
That which does not kill me tends to really piss me off.
bearslayer is offline
post #24 of 64 (permalink) Old 09-04-2018, 06:28 PM Thread Starter
ChrisHead's Avatar
@texasnurse - Yeah, I too watched that video and got most of the tools he used except the wheel balancer. They will be put to the test soon enough.
Living the dream!!
post #25 of 64 (permalink) Old 09-04-2018, 06:44 PM
KeepRidin's Avatar
Year/Make/Model: 2015 Kawasaki Vulcan S
Displacement/CC's: 649 cc
Color: Green
I went with cheaper spoons instead of the MP, but this left me fighting to break the bead. This past tire I ended up ordering a bead breaker (doubles as a wheel holder while I fight with the tire) and I'll have a better air nozzle for next time, which should fix my current issue of getting air in fast enough (without the valve core) to set the new bead. Ended up taking my front tire to a local shop this last go around and admitting defeat, luckily it took the guy less than 60 seconds and they didn't charge me a dime.
-KeepRidin
KeepRidin is offline
post #26 of 64 (permalink) Old 09-04-2018, 07:00 PM
Synycalwon's Avatar
Year/Make/Model: Sold 16 Vulcan S ABS Cafe (replaced by Z900)
Good info on balancing tires, thanks. Just wanted to bring it up in case anyone else reading the thread later would have the info.
I don't really have the setup to attempt it myself (apartment complex with no garage), even if I did no longer have the patience to mess with that kind of stuff. So I'll stick to letting the dealer do the dirty work while I grab a bite to eat and chill at a restaurant nearby.
Synycalwon is offline
post #27 of 64 (permalink) Old 09-05-2018, 12:14 PM Thread Starter
ChrisHead's Avatar
@Synycalwon - I like that plan but with a kid in college and another on the verge of college I'm saving my pennies...lol As well, my son just got a starter bike so I want him to learn these habits from the beginning. Hopefully it all goes as smoothly for me as it does on the YouTube videos and I don't end up having to take them to a local shop to get them over the finish line as @KeepRidin did.
Fingers crossed!!
Living the dream!!
post #28 of 64 (permalink) Old 09-05-2018, 12:20 PM
texasnurse's Avatar
Tire Question
I had trouble getting the tires on the bead, make sure to get the bead nice and soapy and try several times to air up with full PSI I have a 60gallon 6 psi compressor ;a pancake compressor wonít do it. I had to bounce the tire a few times to seat the bead.
Oh and replace the valve stems, you will need a valve tool; I also have leftover valve stems (factory size) and basic pulling tool.
PM if interested.
post #29 of 64 (permalink) Old 09-06-2018, 08:16 AM Thread Starter
ChrisHead's Avatar
@texasnurse - Damn, wish I had logged in last night to see your offer and that I'd read the service manual before last night and seen the recommendation to replace the whole valve as my plan was to just remove the core (tool purchased) and put it back in as was done in the MC Garage and other videos I watched.
In terms of the air compressor I have a fairly beefy one so will crank up the PSI and hopefully will be ok. And yes, plenty of soap. MC Garage used Windex ... based on your experience do you have a preferred lubricant?
And speaking of the manual, I will need to go to the auto parts store and get some high temp grease.
As for the valve puller and stems, I will send a PM...THANK YOU!
Chris
Living the dream!!
post #30 of 64 (permalink) Old 09-06-2018, 08:47 AM Thread Starter
ChrisHead's Avatar
What size rubber valve stem does our beloved Vulcan S use?
Same on front and rear?
If I'm going to replace them I will need to get the right ones and unfortunately if the info is in the service manual I didn't see it and I'm at work now so not in position to check. And just in case I can't work out timing with @texasnurse this morning I may go ahead and order from Amazon...but before I do that I need confidence I'm ordering the right size.
Looking at Bikemaster I see they have 10mm and 15mm rubber valve stems. Interestingly they have two different 10MM stems, the TR412 and TR413, but I don't see any explanation of the difference between the two on their site. As well, their 15mm stem is also labels TR412. I am confused...LOL!!
Finding a stem puller isn't nearly so complicated but if I'm going to the route of replacing the entire valve stem I damn well need the right one.
Who knows the answer?
Living the dream!!
Tire Pressure Question - Which One is Right? / Preload Adjustment Question BobinNC Vulcan 900 12 05-11-2018 11:32 AM
230 tire with the 240 fat tire Fender NorThai Vulcan 900 5 04-28-2011 08:19 AM
Tire upgrade same rim different size tire 230/60B15 BlackedOutVulcan Vulcan 900 0 08-03-2010 02:56 PM
Tubeless tire vs. tube tire dpmooretn Wheels and Tires 3 07-30-2009 01:08 PM
