How do I clean this? - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 6 (permalink) Old 05-14-2019, 07:52 AM Thread Starter
CRU
CRU's Avatar
Displacement/CC's: 1600
Both the brake and clutch reservoirs look like this. Is there a way to clean and restore them back to at least semi-new condition?
2008 Mean Streak Candy Fire Red
Vance & Hines Big Shots Staggered exhaust
Dyno tuned Power Commander III & K&N air filter
Corbin Young Guns saddle/Kawi Fire & Steel "Touring" Double Saddle
Mapam forward controls
Kuryakyn Constellation LED driving lights w/turn signals
Kuryakyn ISO grips w/stiletto end caps
Kawi OEM backrest
Kawi Fire & Steel windshield
Bad Ace Billet handlebar risers
Signal Dynamics BackOFF XP brake light module
Tourmaster Coaster tool bag
CRU is offline
post #2 of 6 (permalink) Old 05-14-2019, 08:22 AM
Get a green scotch Brite pad or you can make a buffing wheel for a dremel and get after it. Keep the scratches in the same direction. This probably has a clear coat on it that will have to come off. No need to put it back on
Sent from my SM-N950U using Tapatalk
ksgjlg is offline
post #3 of 6 (permalink) Old 05-14-2019, 09:22 AM
Patrick's1500's Avatar
Year/Make/Model: 2004 VN 1500E7
Displacement/CC's: 1470
Color: green over white
You could also try a buffer pad in a cordless drill and some jeweler's rouge. Its what they use to take scratches out of rings and gems and polish them smooth. Last time I used it went into a jewelry store and asked a jeweler where I could get some and he just handed me some. You may want to get some slightly heavier abrasive to cut the corrosion off, but jeweler's rouge should work too, just take a little longer.
Patrick's1500 is offline
post #4 of 6 (permalink) Old 05-14-2019, 09:55 PM
gosupes's Avatar
Year/Make/Model: 2008 Vulcan Custom
Displacement/CC's: 900
Color: Black
That looks pretty deeply pitted. No amount of elbow grease is going to bring that back without sanding out the corrosion.
Rules to live by:
Never trust a fart after a night of fast food.
Never take a laxative and a sleeping aid on the same night.
When riding, wear gear you don't mind having a wreck in.
Don't ride above your skill level.
gosupes is offline
post #5 of 6 (permalink) Old 05-16-2019, 10:09 AM Thread Starter
CRU
CRU's Avatar
I figured it would require some serious work. As for as basic cleaning the residue mess, simple soap and water, an all purpose cleaner?
Kawi OEM backrest
CRU is offline
post #6 of 6 (permalink) Old 05-16-2019, 10:17 AM
I've done this on an old bike. The green scotch bright will pretty close duplicate the original finish and if you can get or make a pad for a drill or dremel it will go much faster. If it's really deep try some 320 grit sandpaper first
ksgjlg is offline
How do you clean your Vulcan? Boscoe General Vulcan Talk 30 10-17-2013 07:57 AM
how clean do you keep your ride? bobby c Vulcan 900 37 08-21-2013 11:49 AM
Clean air hose?? italianhorn Engine Work 3 08-06-2013 04:37 PM
How do you clean cylinder fins? bass567 Vulcan 900 11 04-23-2011 09:03 AM
OK. Took carbs apart to clean them boosted Vulcan 500 11 10-07-2010 04:19 PM
