USB flip phone charging - Kawasaki Vulcan Forum : Vulcan Forums
 2Likes
post #1 of 35 (permalink) Old 02-15-2019, 05:23 PM Thread Starter
VN750Guy**'s Avatar
Year/Make/Model: 2006
Displacement/CC's: 750
Color: Red/black
Does anyone know of a setup where they can charge their flip phone from a USB-type port? Having a flip phone, I'd like to know if anyone knows of this being done. If so I want to run it into one of my saddlebags, out of sight.
Chris Cochran
Retired USAF '74 to '95 AMMO
Engine guard with highway pegs
Luggage rack
GPS on RAM handlebar mount
MCCTs replaced ACCTs
Iridium plugs: DPR7EIX-9
Custom made seat (verrry comfortable)
LED turn signals with rear signals relocated
LED license plate holder
Hard mounted Viking saddlebags
Hard mounted fork tool bag (free from Viking)
LED running lights on custom light bar
National Cycles Low Boy Heavy Duty windshield
Home made lowers
VN750Guy** is offline
post #2 of 35 (permalink) Old 02-15-2019, 05:27 PM
RastaPasta's Avatar
Year/Make/Model: 2006 VC1600 Mean Streak
Displacement/CC's: 1552
Color: Black
If you're just looking for a USB port, they certainly make them for motorcycles. I have a Battery Tender one, where the USB outlet plugs into the quick disconnect end of the battery connection. So when I'm riding I have a USB charger and when it's parked I have a Battery Tender
RastaPasta is offline
post #3 of 35 (permalink) Old 02-15-2019, 05:37 PM Thread Starter
VN750Guy**'s Avatar
Color: Red/black
No, those are easy to get and I'm not concerned about acquiring one for me. I am interested if I can even charge the flip phone at all using a USB port setup. All of the flip phone chargers I've ever seen are wall unit-types.
If it IS possible to do so, then where would I go look for the cables?
Chris Cochran
Luggage rack
Home made lowers
post #4 of 35 (permalink) Old 02-15-2019, 05:38 PM
RastaPasta's Avatar
Color: Black
Do they not use a mini or micro USB?
post #5 of 35 (permalink) Old 02-15-2019, 05:41 PM Thread Starter
VN750Guy**'s Avatar
Color: Red/black
Don't know. As I said, the only charging methods that I've seen for flip phones are the wall units that plug into a normal household two prong plug.
Chris Cochran
Luggage rack
Home made lowers
post #6 of 35 (permalink) Old 02-15-2019, 05:44 PM
RastaPasta's Avatar
Color: Black
It should work, so long as you can find a USB cable with the right end type for your phone. Exactly what that would be is hard to say without knowing what phone you have.
But you can see if it would work, electrically speaking, by looking at the output info on the wall charger for the phone and see if it jives with USB outlets. I reckon it'll work though.
post #7 of 35 (permalink) Old 02-15-2019, 05:49 PM
DKC
Year/Make/Model: 2008 en500c
Displacement/CC's: 500
Color: Black
As long as your phone takes one of the standard USB type cords, here's a quick method I've seen on plenty of bikes coming into the shop, with some personal touches for safety.
Use a 12v power outlet similar to a car's cigarette lighter socket. I use a marine grade socket that has a water resistant cover. Some even have flanges with holes for easy mounting.
I usually wire direct to the battery on both terminals. For safety, I always include an inline fuse holder as close to the positive terminal as possible. I tend to use a 30 amp holder for a standard blade fuse, terminate one end to the battery and solder/heatshrink the wire onto the other. Depending on the application, I'll include a switch in the circuit as well.
The gauge of your wire depends on what your load will be. For a motorcycle, you're not going to pull a heavy load, but it would be handy to figure for a small air pump.
With this, you have a standard socket to use a standard car charger for your phone, plug in one of the little USB adapters, or whatever other setup you need.
As I remember, costs were quite inexpensive to do it yourself. Socket was about $10, fuse holder less than $2, terminals were maybe a quarter each (I buy in hundred packs), and the wire I had laying around.
DKC is offline
post #8 of 35 (permalink) Old 02-15-2019, 06:04 PM Thread Starter
VN750Guy**'s Avatar
Color: Red/black
I'm not concerned about hooking up anything to the bike. I already have a similar setup as DKC describes hiding behind my left side-cover. This is used to power my GPS. When I want to use the GPS I just pop off the side cover, plug things into the end of the battery tender wires and I'm good.
So finding a better bike mounted unit to plug in assorted things to charge isn't an issue. Its the actual USB-to-phone cable that I'm wondering about. They're a dime-a-dozen for smart phones but I haven't a clue if they exist for my Verizon LG flip phone.
Chris Cochran
Luggage rack
Home made lowers
post #9 of 35 (permalink) Old 02-15-2019, 06:07 PM
DKC
Color: Black
VN750, can you post a pic of the charging port on the phone and/or tip of your charger? That might go a long way to solving your question.
DKC is offline
post #10 of 35 (permalink) Old 02-15-2019, 06:19 PM Thread Starter
VN750Guy**'s Avatar
Color: Red/black
Never have mastered the art of posting here.
The cable used to charge the phone looks like this:
One end is a standard two prong deal that plugs into a wall for power. The actual charger portion of electronics (weighing several ounces) is attached to the prongs and is a few inches long and high. The other end that goes into the phone winds up being the flat 9/16th inch wide by 1/4 inch deep plug. This fits into the corresponding slot on the bottom of the phone.
Chris Cochran
Luggage rack
Home made lowers
USB charging dock, switch 12V Pardner Vulcan 500 13 08-23-2018 02:13 PM
Phone Charging rheimy Vulcan 650 S 12 07-31-2018 10:30 PM
New USB Plug for My Voyager! rverhalen Vulcan 1700 1 04-15-2018 04:54 PM
95 Vulcan 88 1500A9 charging problems. Graves Vulcan 1500 7 02-20-2017 04:05 PM
Cig lighter socket not properly charging Phone jerryneyk Vulcan 500 11 04-09-2011 08:27 AM
