VN2K transmission hard clunk - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 9 (permalink) Old 06-20-2019, 12:36 PM Thread Starter
Year/Make/Model: 2008 VN2000
Color: Black/Silver
Hello all from Alabama.
I picked up my 2008 VN2K on Father's Day! My very first cruiser. Taking it slow with only going down to the end of my street ( 2miles each direction ) and back getting use to the weight/torque/balancing/handling.
My question to everyone is this.... should it sound normal when I put her in 1st that there is a very LOUD and felt CLUNK ? all other gears shift up and down fine, it's just that initial from neutral shift that it makes the noise.
randypenn88 is offline
post #2 of 9 (permalink) Old 06-20-2019, 01:18 PM
CRU
CRU's Avatar
Displacement/CC's: 1600
The clunk into first is common on many bikes. Without seeing or hearing it, it's hard to say if it's an issue or not. As long as it doesn't jerk forward when it happens it should be fine. Also, make sure your clutch cable is adjusted properly. Owner's manual will explain it.
2008 Mean Streak Candy Fire Red
Vance & Hines Big Shots Staggered exhaust
Dyno tuned Power Commander III & K&N air filter
Corbin Young Guns saddle/Kawi Fire & Steel "Touring" Double saddle
Mapam forward controls
Kuryakyn Constellation LED driving lights w/turn signals
Kuryakyn ISO grips w/stiletto end caps
Kawi OEM backrest
Kawi Fire & Steel windshield
Bad Ace Billet handlebar risers
Signal Dynamics BackOFF XP brake light module
Tourmaster Coaster tool bag
CRU is offline
post #3 of 9 (permalink) Old 06-20-2019, 01:25 PM Thread Starter
Color: Black/Silver
Thanks CRU.... so far it has not jerked or even offered to move until I start into the friction zone with the clutch.
I plan on taking it to the local dealer-shop just to have a once over done on her , as I am now the 3rd owner.
post #4 of 9 (permalink) Old 06-20-2019, 01:39 PM
Sabre-t's Avatar
Color: Red/Black
Agree with CRU, a lot of bikes, especially cruisers, have a clunk when shifting in the lower gears and some even in the higher gears. As long as it shifts easily, it is probably OK.
Some people like the clunk. I do. I've only had two bikes, both cruisers (Honda Sabre and the Voyager) and they both had the clunk. Test drove a Victory Boardwalk and it had a more pronounced clunk than either of my bikes. Some people get really annoyed that they have to put up with it and even will get rid of a bike just because they can't stand the clunk.
Installed:
Longer Kickstand
Dobeck EJK 3.0
Lucky Mirror Extenders
Wiring for Trailer
Ray's Throttle Mod
Things to do:
LET'S RIDE
Sabre-t is offline
post #5 of 9 (permalink) Old 06-20-2019, 01:59 PM Thread Starter
Color: Black/Silver
It doesn't bother me as long as it is " supposed " to be there. It sounds kinda cool, like it's ready to come to life and roar on down that long slow winding road....
post #6 of 9 (permalink) Old 06-20-2019, 04:38 PM
Archie's Avatar
Year/Make/Model: 2010 Kawasaki Vulcan 900 Classic LT
Displacement/CC's: 900
Color: Blue/Grey
Hi there like CRU stated without actually hearing it it's hard to tell if your bike's clunk is normal or not , I suggest you take it to a mechanic or try locating another VN2K owner near your area and let them listen to it, better safe than sorry, good luck.
Archie is offline
post #7 of 9 (permalink) Old 06-21-2019, 09:16 PM
whoaru99's Avatar
Those are some big, straight cut gears in there. Even after the idle comes down (you do let it come down, right?) there is an authorative clunk into first.
Since there is no tach it's hard to gauge the idle speed, but that might be a consideration too. If you mess with it don't go too low. It's not a Hardley.
whoaru99 is offline
post #8 of 9 (permalink) Old 06-23-2019, 02:14 PM
smedlin's Avatar
Being a wet clutch, could need a oil change
Yes, I'm a Chrome Whore.
2004 Vulcan 2000
smedlin is offline
post #9 of 9 (permalink) Old 06-26-2019, 01:38 PM
dokrok5150's Avatar
Year/Make/Model: 2001 Kawasaki Vulcan Nomad
Displacement/CC's: 1500
Color: Red
It is normal when kicking it into 1st. CLUNK!
dokrok5150 is offline
