How much water wetter? - Kawasaki Vulcan Forum : Vulcan Forums
Go Back   Kawasaki Vulcan Forum : Vulcan Forums > Motorcycle Models > Vulcan 1700
Old 06-22-2012, 09:31 AM   #1
gibi
Default How much water wetter?
Water wetter says one ounce per quart.The 1700 has only 2.5 quarts of antifreeze. Is adding only 2and half ounces going to do anything?? Or do you need to flush and refill to gain an advantage.Just trying to reduce some heat without too much hassle.
gibi is offline   Reply With Quote
Old 06-23-2012, 08:28 AM   #2
flatop
flatop's Avatar
I don't think you add water wetter to the existing antifreeze. I think you flush, fill with water and antifreeze mix (70/30 has been mentioned) and add the water wetter to this new mix.
Depending on where you live the 70/30 mix may be a problem if it gets cold.
flatop is offline   Reply With Quote
Old 06-23-2012, 09:34 AM   #3
bikesrfun
bikesrfun's Avatar
Water Wetter is made to be mixed with the antifreeze and water. Engine ice is the replacement coolant that can be substituted for the antifreeze and use the 70/30 mix.
__________________
Vietnam Vet
2011 Fast Black Vaquero
'03 Mean Streak, gone
but not forgotten
bikesrfun is online now   Reply With Quote
Old 06-25-2012, 12:19 AM   #4
Duff
Duff's Avatar
I consider Water Wetter nothing more than a track day solution. Not for street bikes. It's not an antifreeze and it is made to be changed quite often.
__________________
Duff is offline   Reply With Quote
Old 06-25-2012, 01:11 AM   #5
davidsheek
davidsheek's Avatar
Originally Posted by Poncho Villa View Post
This subject opens a whole can of worms about the process of heat removal. I am saying that to do it correctly you need to put a BIGGER radiator on any motor. Ok, so now the flame wars begin anew.
I'm tempted Ponch but I'm not going to do it.
__________________
davidsheek is offline   Reply With Quote
Old 06-25-2012, 06:12 AM   #6
dwainjohnson
Some believe water wetter works and some do not. I use it and it does help. I used 1 oz. per quart and mixed it with a complete new mizture. It takes longer for the engine to reach operating temperature and it does run just a little cooler. The fan runs for a shorter time than without water wetter. As Poncho states the cure is a larger radiator but for me that is not an option. I give water wetter a thumbs up for what it does and do recommend it.
dwainjohnson is offline   Reply With Quote
Old 06-25-2012, 08:43 AM   #7
wbilotta
wbilotta's Avatar
I agree a bigger radiator would help if you could direct the rejected heat away from the rider. I wonder if we could fit a dual core radiator ? Same length and width, just deeper ?
__________________
2010 Voyager 1700 ABS with heated seats, Grasshopper backrest, Kuryakyn highway pegs and an Ipod because the radio reception fades in and out. Also has a gear whine, fuel gauge that fluctuates too much and a pathetic cooling system.
wbilotta is offline   Reply With Quote
Old 06-25-2012, 12:40 PM   #8
Dr.G
Sometimes I think mother Kaw should scrap the water cooled thing and go to a big oil cooler and deeper fins on the motor. Perhaps bigger fins wouldn't even be necessary, the 1900 Yamaha Strat appears to do well.
Dr.G is offline   Reply With Quote
Old 06-25-2012, 12:53 PM   #9
wbilotta
wbilotta's Avatar
I was trying to engineer a way to tap the oil system for an oil cooler but couldn't find a good spot to tap the pressurized side.
__________________
Old 06-25-2012, 05:24 PM   #10
wbilotta
wbilotta's Avatar
seein that the kaws use the same filter as the yam star series bikes, they make oil cooler manifolds to fit the yams. wouldnt the same fit the kaw?
Yamaha may have drilled/tapped some oil ports to accomodate an external cooler. Kawasaki doesn't have that. I looked around for an oil filter adapter base that gives you two oil ports to attach an external cooler to but the area around the filter is too small.
__________________
Powered by vBulletin® Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Honda Grom Forum Harley Davidson Forum Honda 600RR Forum Kawasaki Forum Yamaha R6 Forum Yamaha FZ-09 Forum
1199 Panigale Forum Roadglide Forum Honda CBR1000 Forum Vulcan Forum Yamaha R1 Forum Yamaha R3 Forum
Ducati Monster Forum Harley Forums Honda CBR250R Forum ZX10R Forum Star Raider Forum Yamaha Viking Forum
Suzuki GSXR Forum V-Rod Forums Honda Shadow Forum Kawasaki Motorcycle Forum Star Warrior Forum KTM Duke 390 Forum
SV650 Forum BMW S1000RR Forum Honda Fury Forum Kawasaki Versys Forum Drag Racing Forum Ducati 899 Panigale Forum
Suzuki V-Strom BMW K1600 Triumph Forum Victory Forums Sportbikes BMW NineT Forum
Volusia Forum BMW F800 Forum Triumph 675 Forum MV Agusta Forum HD Street Forum Suzuki GW250 Forum
Yamaha Motorcycles Victory Gunner Forum Honda Vultus Forum HD LiveWire Forum Ninja H2 Forum Ducati Scrambler Forum Kawasaki Ninja 250SL Forum
