2011 vulcan - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 10 (permalink) Old 11-10-2012, 12:19 AM Thread Starter
Kim
2011 vulcan
The bike has a wining noise in the rear end. 3 different shops tried to adjust the belt from loose to tight still have the wine. they say they hear it before adjustment and don't hear it after.but it is still there. dose any one have any similar problems or an an idea what it could be? thanks
Kim is offline
post #2 of 10 (permalink) Old 11-10-2012, 01:08 AM
Color: Orange SE
You may not ever be able to cure the noise completely. It's just the nature of the beast, something you have to deal with with a belt drive. Some notice it others don't. As long as the belt is adjusted per the specs published in the service manual, and the wheel is tracking properly, you shouldn't have any problems (other than noise!)
How many miles are on the bike? Some have reported the noise goes away after a few thousand miles.
Romans5.8 is offline
post #3 of 10 (permalink) Old 11-10-2012, 11:54 AM Thread Starter
Kim
It has just over 14000 miles. someone else told me this but the noise is so loud i was hoping it was something i could fix. Thanks Romans5.8
Kim is offline
post #4 of 10 (permalink) Old 11-27-2012, 12:36 AM
Aussie.Nomad's Avatar
Year/Make/Model: 2010 Vulcan Nomad
Color: Black & silver
Try spraying it with wd 40, a silica spray,(preferrable) or similiar
Aussie.Nomad is offline
post #5 of 10 (permalink) Old 01-04-2013, 09:26 PM Thread Starter
Kim
your not serious are you? wd 40 on the belt.
Kim is offline
post #6 of 10 (permalink) Old 01-04-2013, 11:26 PM
Have used it several times on the Roadsta,r1st belt I took off at 114,000 kilometres, 2nd belt is still on at 208,560 kilometres, the 1st is a good spare.
post #7 of 10 (permalink) Old 02-16-2013, 10:43 PM
Ken Means's Avatar
You might try glass beading the belt contact area on bought pulleys. Some times they get some road films on them and squeak as they make contact to the pulley. Clean it off and reassemble as to belt specs.
Ken Means is offline
post #8 of 10 (permalink) Old 02-16-2013, 10:55 PM
Color: Orange SE
WD-40 is not a lubricant. It's a water dispersant. If it worked, it probably worked because WD-40 has an uncanny ability to suck it grime, dust, and moisture and become really sticky and gummy (from the dust) as it dries. That may have quieted it down just by creating a layer of 'gunk' as an insulator.
post #9 of 10 (permalink) Old 02-16-2013, 10:56 PM Thread Starter
Kim
Ok. I guess you are serious.
Kim is offline
post #10 of 10 (permalink) Old 03-28-2013, 01:44 PM
have you checked to make certain the wheels and sprockets are properly aligned? I know nothing about belts, I have a 1600 w shaft drive, but it seems to me that would be something to check.
mrbreeze is offline
