Debaffling a 2010 1700 Nomad - Page 2 - Kawasaki Vulcan Forum : Vulcan Forums
post #11 of 15 (permalink) Old 12-03-2012, 05:21 PM Thread Starter
davewhyte69's Avatar
Whereabouts are you?I'm heading to Lake Maquarie on Friday,Warners Bay area,but will be doing a little riding around.
davewhyte69 is offline
post #12 of 15 (permalink) Old 12-04-2012, 12:23 AM
Aussie.Nomad's Avatar
Year/Make/Model: 2010 Vulcan Nomad
Color: Black & silver
Live at Swansea, but won't be finishing work before 2.00pm,
pm me with you r number & I will give you a ring
Aussie.Nomad is offline
post #13 of 15 (permalink) Old 05-27-2016, 09:33 PM
REBAR1968's Avatar
just stumbled on this post so the people that have debaffled the pipes just running stock set up as far as intake ??and air filter any lean running issues ?
REBAR
REBAR1968 is offline
post #14 of 15 (permalink) Old 05-27-2016, 10:36 PM
rick's Avatar
I had 2 baffles drilled from each pipe for about 6 months the stock air system. Seemed to run ok, but was a BIG improvement after adding the Thunder stock air kit and Gman/Bully (EJK) at the same time. Responce in the 2200-2800 rpm was were I saw the biggest improvement.
2005 800 classic
2012 Voyager ABS
rick is offline
post #15 of 15 (permalink) Old 05-28-2016, 05:33 AM
Diggles's Avatar
Year/Make/Model: 2012 Nomad
Color: Red & Silver
I drilled out the last 2 plates when I got the Nomad last year however as I did it the day I picked it up can't be sure of any improvement. Added the EJK & chuckster BAK which woke her up, but the V & H slip ons really kicked her out of bed. If I was in the USA I would be seriously be thinking of getting the ECU reflashed.
2005 Classic 800 (sold)
2012 Nomad 1700
Dobeck gen 3 EJK,Chuckster BAK
RACNRAY throttle mod,Avon Air grips
Vance & Hines slip ons
HD highway pegs
Grasshopper backrest
Vulcan pannier liners
Sena 20S .
S/Steel pannier kick guards
Custom lowers
LED running lights
Diggles is offline
