Headlight Bulb Replacement - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 5 (permalink) Old 04-30-2010, 07:59 AM Thread Starter
vulcan800's Avatar
I have read that the stock 55/60 headlight bulb (01 Vulcan 800) can be replaced with other bulbs such as a 80/100. What does these two numbers mean (is it wattage at low/high beams)? Are the numbers interchangeable (ie. saw them online as 100/80 - are they the same bulb)? And, has anyone had problems from switching to a brighter bulb?
I'm also seeing a lot of 100/90 bulbs on Ebay. would these work as well?
Thanks!
vulcan800 is offline
post #2 of 5 (permalink) Old 07-10-2010, 10:10 PM
Savoie69's Avatar
I've done that on my car, result = had to change plugging and wiring because it was to big for it so it melt pluggin and wires...but maybe your bike will be good. Check witch someone who knows a little bit electricity and he will be able to tell you that,
Savoie69 is offline
post #3 of 5 (permalink) Old 07-10-2010, 11:32 PM
slaponte's Avatar
Send a message via MSN to slaponte Send a message via Yahoo to slaponte
Vulcan800, if you go to a higher watt bulb AND you have other additions on the circuit (for example a light bar) you might blow the fuse for that circuit. So its a matter of how much can that circuit hold. But worst case you burn up the fuse and then you know.
Actually, I just went to a Sylvana H4 bulb on my 1600. It is still 55/60 but supposed to be brighter. We will see. A bulb highly recommended is the Wagner Bp1210/H4 you can find it at NAPA. It is rated 80/100.
VROC # 27462
2003 Kawasaki Vulcan 1600 Classic :
slaponte is offline
post #4 of 5 (permalink) Old 07-11-2010, 12:02 AM
RHKman's Avatar
I went to the 80/100 have used it for about 6 months now without any problems. It is realy bright and puts out almost as much on low beam as other did on hight beam.
Live to ride and keep it safe
Robert
2011 Victory Vision pearl white/ Pearl the White Lady
1999 VN800b4 classic
Mods
1 kury iso flame grips
2 cobra slash pipes
3 cobra floor boards
4 MS fats windscreen
5 kury iso highway peggs
6 kawi light bar
7 kury mirrors
8 kury swingwing pass peggs
9 sissybar with pass back rest and rack
10old leather saddle bags
11 hard chrome volt meter
12 mustang solo seat with back rest
RHKman is offline
post #5 of 5 (permalink) Old 07-12-2010, 09:55 PM
55/60 zenon made a big difference over the stock bulb. And, it's available at any NAPA auto parts. I guess it's a different gas in the bulb
stevieb is offline
