Gas is leaking from carb under bike? - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 7 (permalink) Old 03-01-2010, 11:59 AM Thread Starter
I have a 1998 Vn 800, & after running it i turn it off & gas leaks out from under the bike, from the carb.The bike runs great,but (sometimes) it leaks gas out of the tube that runs down from the carb? need answers plz can anyone tell me what is up with it? & what should i do to fix? Thanks!!!
thrill007 is offline
post #2 of 7 (permalink) Old 03-01-2010, 06:34 PM
SparHawk1967's Avatar
is it on prime? if not possible float needle stuck.
2007 VN900 Classic Lt
Chromed Cup Holder
R.F.T.S.
does not matter what you ride
Just Ride Baby Ride
SparHawk1967 is offline
post #3 of 7 (permalink) Old 03-01-2010, 06:46 PM Thread Starter
Question prime??
I rode it today, & it didnt leak a drop! ? ! Went about 25 miles,stoped & turned it off to see if it would leak? I did this 4 different times. No Leaks! HUmm..It ran Great! dontno whats up with it?
post #4 of 7 (permalink) Old 03-01-2010, 06:57 PM
reddyford's Avatar
Hey, check your hose clamp at the carb.
Takes two bikers to fill a Tank! LOL
reddyford is offline
post #5 of 7 (permalink) Old 03-01-2010, 08:06 PM Thread Starter
Its not comming from the clamp at the carb! Its comming out the tube that's at the bottom of the carb, that runs down to the bottom of the bike,& runs out on the ground ! ? looks like a over flow tube!
post #6 of 7 (permalink) Old 03-03-2010, 08:32 AM
Shiloh's Avatar
That is what it is, an overflow. Sounds like a bit of dirt on a float valve, or a sticking flow that has work itself free. Tends to happen somewhat more often when they sit for long periods of time, like winter.
A little Seafoam or fuel system cleaner won't hurt, but may not be needed.
09 Vulcan 900 Custom - Traveller
09 FZ 6 - Lakota
Shiloh is offline
post #7 of 7 (permalink) Old 03-04-2010, 09:50 AM
Its possible that your needle and seat are worn out and needs replacing.
ghostrider
ghostrider460 is offline
