Batwing options??? - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 16 (permalink) Old 12-15-2012, 02:19 PM Thread Starter
Batwing options???
Hey guys, I have some changes in mind for a winter project.
I have a 2000 800B (classic) and my plan is to make a bagger out of it. Im going to change the pipes to a 2 into 1 and put some nice big hard bags on.
What are my options for a bat wing? Im comfortable with having to fab a bracket but what would be a good piece to start with? How about this one. It lists the 800A as compatible, shouldnt I be able to modify it to make it work?
Im not familiar with the 800a front end.
http://www.tsukayu.com/QuickDetachab...ngforDyna.html
foxbat is offline
post #2 of 16 (permalink) Old 12-15-2012, 10:01 PM
bamadrive's Avatar
the difference is the upper fork covers the A doesn't have them. as far as I can tell that will be your only problem
why don't you contact them? it says they offer custom fittings for bikes not listed, for that kind of money I think I would let them do it.
bamadrive is offline
post #3 of 16 (permalink) Old 12-16-2012, 10:07 AM Thread Starter
thanks guys
If the difference between the A and B is the for covers, then that should be no big deal to just remove them.
foxbat is offline
post #4 of 16 (permalink) Old 12-17-2012, 01:38 PM
Bob Myers's Avatar
I put an older HD batwing on my 800A, the upper covers would have been in my way to do it the easy way, could easily remove them or use large stainless hose clamps around them.
The stuff that'll fit a 1500 classic will fit an 800 classic as well. They share almost a 100% interchangeable parts list on th forks.
'98 800a w/aluminum wheels/tubeless tires
Iron Butt Ass.#34911
Bob Myers is offline
post #5 of 16 (permalink) Old 12-17-2012, 02:05 PM
Graybush's Avatar
In addition to all the options already mentioned, the Memphis Shades Batwing is compatible with a lot of bikes. Since you mentioned making your own brackets, you may also want to check Wide Open Customs and Hoppe. Neither of those specify the 800 on their website but you might be able to make it work.
2014 Triumph Tiger Explorer
2008 Yamaha XT250
War Eagle
Graybush is offline
post #6 of 16 (permalink) Old 12-18-2012, 10:39 PM
CycloneRider's Avatar
Thinking of doing a quick release batwing style build on my next bike. Here is another option that is really affordable, but does not have a inner panel:
http://www.mutazu.com/products.php?c...380&s=prod.php
CycloneRider is offline
post #7 of 16 (permalink) Old 12-19-2012, 08:20 PM Thread Starter
So I should be able to just take the upper covers off and be good right? Maybe some small mods?
foxbat is offline
post #8 of 16 (permalink) Old 12-19-2012, 08:35 PM
Bob Myers's Avatar
Depending on how the lower mount works you may be able to use a stainless hose clamp over the covers and not have to fuss with taking them off
post #9 of 16 (permalink) Old 12-19-2012, 09:52 PM Thread Starter
Thanks Bob. Ill post some pics when I get started on it.
foxbat is offline
post #10 of 16 (permalink) Old 12-23-2012, 03:55 PM
I put a street glide fairing on my bike and mounted to a windshield
dale44 is offline
