Rear Brakes....how hard? - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 7 (permalink) Old 11-23-2012, 08:07 PM Thread Starter
Looks like I am at the end of the adjustment. How hard are the rear brakes to replace? I have a manual. Thanks for the help.
davemn is offline
post #2 of 7 (permalink) Old 11-23-2012, 10:28 PM
Comanche's Avatar
Not hard at all whether rear or front.
Comanche is offline
post #3 of 7 (permalink) Old 11-23-2012, 11:51 PM
rick's Avatar
You have to pull the rear wheel, but not hard at all once wheel off. Make sure speedo drive in hub is engaged before you tighten axle. If not speedo will quit before long. Should be about a 1/16" gap between center hub, and brake backing plate all the way around.
2005 800 classic
2012 Voyager ABS
rick is offline
post #4 of 7 (permalink) Old 11-27-2012, 04:11 PM
griffjo's Avatar
davemn,
Just curious - what model and how many miles?
At just over 33,000 miles, my '03 Classic is just about 30% into "Usable Range". At this rate (if the "guage" is close to accurate), I could get 85,000 to 100,000 miles on the OEM rear brakes.
We shall see.
GRIFFJO
Montani Semper Liberi
2003 Vulcan® 800 Classic - Pearl Mystic Black
National Cycle Custom Heavy-Duty Windshield
Mustang Two-Piece Wide Vintage Touring Saddle
Volar SissyBar/Backrest - K&N Air Filter
Viking Quarter Circle SaddleBags & SissyBar Bag
Scootworks Sprockets (18/40 - 2.222:1 ratio)
Baron 3" Bullet Tachometer - Engine Guard (black gloss finish)
Michelin COMMANDER II front 130/90-16 73H, rear 140/90-16 77H
EK X-Ring Chain, Deer Warning Whistles & BackOFF® Brake Module
griffjo is offline
post #5 of 7 (permalink) Old 11-27-2012, 04:44 PM
rick's Avatar
I replaced my rear brakes at about 87,000 miles, but how you use it, and the type of riding you do will affect the life of them. The guage on the rear hub is just a guide, to know if they are really worn out, you need to remove the wheel and look at them. I say this because even them length of the chain can make the guage read different. The next time you have to tighten your change, pay attention to your rear brake peddle, if you dont adjust the brake, the pedal will have less travel before grabbing. When I bought my bike new, the adjuster was between 1/3 and 1/2 way used with everything new. The dealer told me I could remove the lever on the rear hub and move it back 1 or 2 splines and the indicator also moves further back to the usable range and you dont have so much rod sticking out of the adjuster. A smaller sprocket on the rear will also affect how it reads.
rick is offline
post #6 of 7 (permalink) Old 11-27-2012, 05:32 PM
If you are close to needing a new rear tire you might as well do that at the same time. Changing the rear brake shoes though is not difficult.
Sent from my Desire HD using Motorcycle.com Free App
2000 VN800B
Phil in Maine is offline
post #7 of 7 (permalink) Old 11-27-2012, 05:50 PM Thread Starter
All good points guys. The bike has 25,000 miles. I bought it 2 yrs ago so I have no history on the bike. Sounds like a spring project.
davemn is offline
