Possible fuel problem? - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 18 (permalink) Old 11-18-2012, 06:53 PM Thread Starter
rick's Avatar
Went for a ride today, the weather was great. Had little issue 3 times while out. twice at around 45 mph as I cranked the throttle, it would start to take the gas, then cutout like it was running out of gas, for maybe 1/2 a second, then pick back up and go. Both times was accelerating through a turn when it happened. The third time was stopped at a red light. Opened the throttle to pull off when light turned green and started letting clutch out, and cutout again, almost stalling this time, then took off like normal. Nothing been changed on motor or exhaust in over 2 years.Did change plugs about 2 months ago, but been running fine. Has open mufflers, grampsized with K&N filter, and carb jetted 4 years ago. Dont beleive any of these are the problem because been fine till today. No backfiring, or hesitations noticed. Dont believe is ignition. Just like it ran out of gas. Any ideas?
rick is offline
post #2 of 18 (permalink) Old 11-18-2012, 08:31 PM
Comanche's Avatar
Hey Rick. Sounds similar to what happened to me today. Not kidding! Were you in 4th gear? I was in fourth gear when this happened to me just like you're explaining here. The thing is I'm fine tuning the new carb I installed so I know I need more fuel since everything is new. As for you though, besides the sputtering and hesitation did it pop or backfire slightly on decel? How are your vacuum lines?
The other thing is that I have an HD tank on my VN800B Classic that was installed by the PO so I know its quirks already. Specifically, it has a variable rate flow tap that maxes out at a certain point and so as I was riding I just opened it up a little at a time until it stopped doing this. Sounds like you may be running slightly lean so it could be something as simple as a slight adjustment since you said you haven't had any issues for four years running now. Needles wear over time and the slightest changes cause fuel metering and atomizing issues so my first bet is on a simple adjustment of your pilot since you said you have such a good running record and this ONLY after ensuring your carb is clean. Sometimes the slightest loose fit on the airbox and housing is enough to offset things. Any cracks in the housing or anywhere else? I'm must giving you things I would look for if the bike were mine.
Have you changed fuel type or brand? I only ask that because mine seems to run better on Techron type fuels and if I can't find that I try QT. Don't know why but hey from what I've read the 800's are temperamental beasts.
Did you check the plugs yet to see how they look like? Sometimes, a CDI can cause this too. Did you wash it recently and get some water accumulation in the bowl? Have you cleaned out the bowl through the drain? Have you checked your float operation and fuel level? How is the rubber on the intake manifold? Is it cracked or loose? How is the manifold? The transition from carb to intake manifold needs to be sealed and pretty much airtight so that airflow metering is correct and the bike burns fuel efficiently based on your ideal settings that is.
Sometimes a hidden short in the harnesses or a faulty or loose lead on the IC's going to the plugs may cause this. Some will even say that if you have had NO PROBLEMS at all until now to just use some SeaFoam but I'm sure you already know that.
Since you said your bike's Grampsized is the crankcase vent hose still attached to your air filter housing? Sometimes that thing creates oil accumulation so severe that it may slightly impede performance like this and the fix is to just clean it since you have a K&N setup or replace the filter for those who are unable to clean their filters. What I did for this vent line was remove and run it to top left side of the radiator on the left side downtube, up around the front span across the spine through the harness hole, back down the right side downtube and attached a small inline fuel filter on the end as a trap. It helped mine breath better and cleaner. Another guy on here made a trap with PVC and placed it inside of his right side EPA cover area.
Give her a thorough inspection to ensure all is in order. Whatever you do please post back though because I'm interested in seeing what you find out to be the problem and how you resolve it since you have such a longstanding excellent track record with your bike.
You remind me of those few individuals who have a vehicle for years and they end up getting a new one from the manufacturer. Who knows? Contact Kawasaki and tell them how well you have been doing with your bike and maybe you will hit them up during a charitable time in their corporate image outlook and they'll give you a brand new bike because of your success!
Comanche is offline
post #3 of 18 (permalink) Old 11-19-2012, 04:10 PM Thread Starter
rick's Avatar
Been using seafoam last couple years, a few ounces each oil change. Havent had time today to do much with it. Going to pull the plugs tomorrow and see what they look like. Probably clean the air filter also. Thinking may have gotten a little bad gas, filled up just prior to riding. Carb was last off and cleaned about 2 years ago. Be nice if ma kow would give me a bike to ride for 4-5 years, not counting on it.
rick is offline
post #4 of 18 (permalink) Old 11-19-2012, 09:52 PM
Comanche's Avatar
Roger that, Rick. Wish you success because you're an inspiration for all of us Vulcan owners by having such a longstanding successful track record of running uptime.
Comanche is offline
post #5 of 18 (permalink) Old 11-19-2012, 10:11 PM Thread Starter
rick's Avatar
Thanks! Dont do much to it but change oil and ride. Guess I've been lucky with it. If weather holds out, intend to have 100,000 by end of the year. Would definetly recommend it, and buy it again.
rick is offline
post #6 of 18 (permalink) Old 11-20-2012, 01:02 PM Thread Starter
rick's Avatar
Puuled the plugs a little bit ago. The 1st 2 pix are from the back cylinder. The last 2 are the front. They have about 5,000 miles on them. Seem ok. Click image for larger version
Name:	ImageUploadedByMO Free1353438073.246608.jpg
ID:	14284Click image for larger version
Name:	ImageUploadedByMO Free1353438084.879674.jpg
ID:	14285Click image for larger version
Name:	ImageUploadedByMO Free1353438101.766174.jpg
Name:	ImageUploadedByMO Free1353438113.044282.jpg
2005 800 classic
2012 Voyager ABS
rick is offline
post #7 of 18 (permalink) Old 11-20-2012, 01:04 PM Thread Starter
rick's Avatar
Only concern is the rear plug has black streaks, but only on 1 side of plug, not both.
2005 800 classic
2012 Voyager ABS
rick is offline
post #8 of 18 (permalink) Old 11-20-2012, 05:11 PM Thread Starter
rick's Avatar
Just got back from 135 mile ride, ran perfect. Maybe just had moisture in tank?
2005 800 classic
2012 Voyager ABS
rick is offline
post #9 of 18 (permalink) Old 11-20-2012, 07:50 PM
Comanche's Avatar
Glad to hear that Rick. You keep a good eye on her that's for sure. I'm sure you'll stay on top of her if she acts up again but I also hope it was only water or slight contamination like you said. I want to see you keep riding it for at least another 100K! Hope you and your family have a Happy Thanksgiving.
Comanche is offline
post #10 of 18 (permalink) Old 11-20-2012, 07:53 PM
Comanche's Avatar
Sometimes anti-seize might do that or some tiny amounts of sludge buildup that suddenly circulates loose inside the engine. When's the last time you cleaned your oil screen? I had to do a thorough cleaning on this beast I have because the PO was a real hack.
Comanche is offline
