Previous Owner's Problems Inherited - Page 4 - Kawasaki Vulcan Forum : Vulcan Forums
post #31 of 37 (permalink) Old 11-12-2012, 11:00 AM
pacomutt's Avatar
Originally Posted by MN-Rider View Post
Umm it doesn't happen. Once a user is banned, all his past posts will show his new user title as banned.
Can you just name yourself "Banned" like apparently you can call yourself "Top Contributor"?
Ron in Cincinnati
.........Bob Seger
pacomutt is offline
post #32 of 37 (permalink) Old 11-12-2012, 11:02 AM
Administrator
MN-Rider's Avatar
Displacement/CC's: 1800
Color: Pearl White
Name yourself? Sounds like you are referring to the username, I was addressing the user title and it cannot be changed by the user. The "Top Contributor" user title changes automatically based on number of posts.
Jeff, Twin Cities, MN
*You will be able to view signature links after you make two posts in the forum*
MN-Rider is offline
post #33 of 37 (permalink) Old 11-12-2012, 01:48 PM
XCR600's Avatar
Originally Posted by Comanche View Post
Ok, so here's the deal. Since the bike was new to me I gave this thing a thorough inspection and servicing. I replaced parts here and there that needed to be replaced according to OEM specs and got it running.
Installed the following: new wiring harness because old one was too hacked up by PO, a new CDI because it was cracked and out of specs, faulty R/R out of specs, old frayed pickup coil, old frayed positive & negative battery cables, new tank assembly. It's running now so I'm taking the beast out today to fine tune the carb.
Does anyone recommend using a little PermaTex High-Temp Red around the aluminum ring gaskets for the exhaust pipes to seal them better? I've done it on my HD's in the past so just wondering what you Vulcans do besides tightening to OEM torque specs.
Thanks for all your help and input gentlemen.
These should be crush fit gaskets , no sealant needed. I used some anti seize on the flange bolts though.
95 800A
Memphis shades Demon
Vance & Hines Cruzers
Jardine Rack
Kuryakyn Dually pegs
Baron Risers
Kuryakyn ISO grips
Kuryakyn long horn hwy pegs
Wille&Max saddle bags
XCR600 is offline
post #34 of 37 (permalink) Old 11-12-2012, 03:24 PM Thread Starter
Comanche's Avatar
Roger that, XCR6. Have a good holiday.
Comanche is offline
post #35 of 37 (permalink) Old 11-12-2012, 03:27 PM Thread Starter
Comanche's Avatar
Yes, the area that changes automatically showed Banned underneath his User ID. It was hilarious to me how that could happen and dude's posts bordered on the rude side so I can only imagine what he posted to piss off people and deserve such a dubious distinction and title. Haha!
Comanche is offline
post #36 of 37 (permalink) Old 11-12-2012, 04:47 PM
XCR600's Avatar
Funny thing about this is , I just got a Harley and I'm changing the exhaust once it gets here. So I should use some red RTV on the flange gaskets ?
It's a 88 BT.
95 800A
Jardine Rack
Baron Risers
Kuryakyn ISO grips
XCR600 is offline
post #37 of 37 (permalink) Old 11-12-2012, 06:24 PM Thread Starter
Comanche's Avatar
It's a 88 BT.
XCR6, use the UltrBlack! My bad for mis-communicating here. I was thinking red at the time due to my little niece asking me which color balloon matched her hair ribbon. Haha! Sorry for the momentary lapse in thought. Just use a small amount around the mouth and gaskets and torque to specs.
Comanche is offline
