Previous Owner's Problems Inherited - Page 2 - Kawasaki Vulcan Forum : Vulcan Forums
post #11 of 37 (permalink) Old 11-07-2012, 10:19 PM
pacomutt's Avatar
Originally Posted by Comanche View Post
PacoMutt, what is the procedure to bring the piston up part way on the exhaust stroke so the exhaust valve is open?
A really quick and dirty way would be to place the shop-vac hose tightly against the exhaust port, and if it doesn't unload the motor (like holding your hand over the end of the hose), then the exhaust valve is already open.
Since you don't have a compressor, and if you don't want to use some canned air or similar, just have the plugs removed, use the shop-vac on the port, and crank the engine over a couple of times. There won't be enough debris left behind to cause any concern.
Don't even think about pulling the head; not that you could do it with the engine in the bike anyway.
Ron in Cincinnati
.........Bob Seger
pacomutt is offline
post #12 of 37 (permalink) Old 11-07-2012, 10:28 PM Thread Starter
Comanche's Avatar
Right, PacoMutt. I wouldn't even think about removing the head for something this quick and easy since removing the engine would have to come first and that's even more overkill.
SFair, the battery is new and fully charged and has already been load tested from the store where I bought it. That's why I moved on to the REC/REG and will keep going unless you can suggest some reasons why there is NO JOY coming to the left side of the bike? However, I would really like to learn how to load test at home so please fire away at your discretion.
When I began the thread I stated all that was checked and worked at the time so without taking up room please read that and see if there is also anything else you can think of. Thanks guys I appreciate it.
Comanche is offline
post #13 of 37 (permalink) Old 11-07-2012, 10:31 PM Thread Starter
Comanche's Avatar
PacoMutt, I got lost on the "unload the motor like holding your hand over the end of the hose" part. Trying to imagine that but do you mean the way vacuum pressure works when simply placing a hand onto a vacuum's hose?
Comanche is offline
post #14 of 37 (permalink) Old 11-08-2012, 01:23 AM
pacomutt's Avatar
I was talking strictly about the vacuum, not the motorcycle's engine. If you plug the end of the vacuum's hose, the electric motor speeds up, because when the vacuum cleaner is not moving air, the motor "unloads".
If you put the hose tight against the port, and the exhaust valve is still closed, the vacuum will speed up. Turn the motorcycle's engine over until the vacuum starts pulling air thru the spark plug hole and the vacuum cleaner sound returns to normal. You're just trying to vacuum out the cylinder through the exhaust valve port, but the valve has to be open to do that.
Ron in Cincinnati
.........Bob Seger
pacomutt is offline
post #15 of 37 (permalink) Old 11-08-2012, 08:19 AM
markstep's Avatar
Send a message via Skype™ to markstep
Don't wish to delay the thread, but I thank you for the explanation of cleaning the cylinder. A poor day when you don't learn something!
2003 1500 Meanstreak
Hardchrome pipes
saddle bags
MS hot shot windscreen
Fuel Genies
not sure what else added by p/o
markstep is offline
post #16 of 37 (permalink) Old 11-08-2012, 11:08 AM
Ok, if you could do this:
1. Take voltage reading across battery.
2. Turn on key. Take another reading.
3. Leave key on for five minutes. After time up, take another reading.
Post back with 3 readings.
Do your running lights work?
sfair is offline
post #17 of 37 (permalink) Old 11-08-2012, 04:19 PM Thread Starter
Comanche's Avatar
Thanks SFair. Here are the battery readings:
1. 12.81V
2. 12.71V
3. 12.63V
After 1/2 hour the battery recovered on it's own to 12.79V.
Taillight/license plate light works but no brake light. The PO removed all other running lights so there are only the receptacle leads remaining.
Here are the REC/REG readings:
1. 1.8
2. 1.7
3. 1.7
4. 0
5. 0
6. 0
7. 0
8. 0
9. 0
10. 1.8
11. 1.7
12. 1.7
Still have no idea what the readings mean according to the attached OEM charts or what the infinity sign, 1/2 scale or less and the x10 or x100 for Resistance range mean as the meter I'm using is self-ranging and I can also adjust it manually but I'm allowing it to auto-range. Try to learn here so please explain. Thanks SFair.
Name:	Rectifier Chart.jpg
ID:	14141   Click image for larger version
Name:	Rectifier Diagram.jpg
Comanche is offline
post #18 of 37 (permalink) Old 11-08-2012, 04:40 PM
The reg/rect has no bearing on the bike starting or not.
Is that still the problem...push start switch and nothing?
Post back.
sfair is offline
post #19 of 37 (permalink) Old 11-08-2012, 06:05 PM Thread Starter
Comanche's Avatar
Post back.
Yes, of course, SFair, the REC/REG helps on recharging side and not starting side but the only reason I am checking left side components and connections is because there is no flow of current on the left side of the bike like I had originally stated. I will double check connections to see if there is something not connected correctly.
However, the data seems to point to a bad REC/REG if I am not mistaken with its interpretation. The reason I had slight trouble understanding the way the chart is written is because Kawasaki says the OEM Manual is translated from Japanese into English and because of that sometimes the referent(s) are lost in translation so I had to look in other chapters for similar meanings with respect to NO READING, INFINITY, etc.
NO JOY from the Start Switch and it will not turn the bike over. I also don't have power coming to the left side which would be visually evident if the small red LED light that was installed by the PO on the left side cover was illuminated to light up the Ignition Switch area at night.
Attached are two more shots from my camera phone that show the testing procedure for the Starter Relay in the OEM Manual. It only shows a poor diagram of the relay and connection for the battery and meter so I'm having a problem deciphering how to connect and test it so please let me know the best way to connect and test the Starter Relay. All I can tell at this point is that the 30A Main Fuse is OK. Thanks SFair.
Name:	Starter Relay Testing Diagram.jpg
ID:	14144   Click image for larger version
Name:	Starter Relay Testing Procedure.jpg
Last edited by Comanche; 11-08-2012 at 06:11 PM. Reason: Delete typos and edit to make easier to understand.
Comanche is offline
post #20 of 37 (permalink) Old 11-08-2012, 07:41 PM
bamadrive's Avatar
The meaning of the symbols is
upsidedown horse shoe = ohm's or resistance, this is what you are measuring
zero ohm's means there is no resistance, which is either a completed circuit like closing a switch or a short
infinite ohm's means just that infinite resistance which is an open condition
If you had a switch of some sort on the bench to test and turned it on, or closed it you would read zero ohm's, if you then turned it off or opened it you are opening the circuit and would read infinite resistance thus no current flow. There can be no current flowing with out some measurable resistance but it cannot be infinite. The amount resistance determines how much current will flow with a given amount of voltage.
bamadrive is offline
