Speedometer not working - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 16 (permalink) Old 11-05-2012, 11:14 AM Thread Starter
bfitkin's Avatar
Has anyone else had their speedometer / odometer stop working?
I thought it might be the cable was bad, so I changed it. And still nothing.
Could it be the gauge itself or possibly something in the rear hub?
Any thoughts would be greatly appreciated...
'97 VN800B
BCB Kit
-Rear Fender
-Spring Seat
-Biltwell Frisco Bars
-Vance & Hines Straight Shots
-'30 Ford Tail Light
-Relocated Vert Lisc Plate
-Bullet Rear Signals
-Metzler 880 WWW
bfitkin is offline
post #2 of 16 (permalink) Old 11-05-2012, 11:24 AM
SWVA_08V2k's Avatar
Did you spin the cable by hand before you put it on to make sure the cable was good?
If you unhook the speedo side of the cable and turn your wheel, is the cable spinning?
SWVA_08V2k is offline
post #3 of 16 (permalink) Old 11-05-2012, 11:34 AM Thread Starter
bfitkin's Avatar
I checked the new one by hand before conecting it and it did spin. I will check and see if it spins when i turn the wheel when i get home today. So the dumb question is, if it does spin by turning the wheel, i can assume its the gauge?
'97 VN800B
BCB Kit
-Rear Fender
-Spring Seat
-Metzler 880 WWW
bfitkin is offline
post #4 of 16 (permalink) Old 11-05-2012, 11:47 AM
SWVA_08V2k's Avatar
It's a good place to start. As for if there is a fix for the gauge I do not know. Will have to wait for someone else to chime in.
And make sure it is not kinked up or in a bind.
post #5 of 16 (permalink) Old 11-05-2012, 12:20 PM Thread Starter
bfitkin's Avatar
Thanks for the advice.... At least i have some direction now...
'97 VN800B
BCB Kit
-Rear Fender
-Spring Seat
-Metzler 880 WWW
bfitkin is offline
post #6 of 16 (permalink) Old 11-05-2012, 01:30 PM
Just out of curisosity, how do you like the bike with the bobber kit?
2000 VN800B
Phil in Maine is offline
post #7 of 16 (permalink) Old 11-05-2012, 01:38 PM Thread Starter
bfitkin's Avatar
I really like it. I just put some new Biltwell Frisco bars on it. It's really fun to just cruise around town on.
'97 VN800B
BCB Kit
-Rear Fender
-Spring Seat
-Metzler 880 WWW
bfitkin is offline
post #8 of 16 (permalink) Old 11-05-2012, 05:52 PM
rick's Avatar
If the cable is good, the next step would be check the speedomemter receiver in the rear wheel. If not properly seated when the wheel is reinstalled, this part will not allow the cable to spin. May work for awhile then stop. Happened to me. simple fix is, remove from wheel and set in a socket just small enough to jold it and lightly tap it back to streight. The flange will not be at a 90 degree angle to the center. In the following link look at part 41064.
http://www.cheapcycleparts.com/model...ar-wheel-chain
rick is offline
post #9 of 16 (permalink) Old 11-06-2012, 08:33 AM Thread Starter
bfitkin's Avatar
thanks Rick. I will defintely give that a try. I will let you know how it goes. Thanks again.
'97 VN800B
BCB Kit
-Rear Fender
-Spring Seat
-Metzler 880 WWW
bfitkin is offline
post #10 of 16 (permalink) Old 11-06-2012, 11:03 PM
oldrockr's Avatar
Here's what I found when my speedo quit. The receiver was mangled as you can see, compared to the new part. I don't know what caused it, it worked fine for 9K miles after I bought the bike.
Doug
'96 VN800A
V & H Cruzers
F & S Sissy Bar
Unik Fork Bag
oldrockr is offline
