Converting from drum to disc? - Page 2 - Kawasaki Vulcan Forum : Vulcan Forums
post #11 of 19 (permalink) Old 10-02-2012, 12:13 PM
DBallin69's Avatar
Looks great Pacomutt. May have to try that conversion someday. Nice job!
DBallin69 is offline
post #12 of 19 (permalink) Old 10-02-2012, 12:27 PM
DBallin69's Avatar
Looks like that may have taken some work lol. Hope you dont mind if I ask you a question here. I checked my rear plug when I had my seat off and its barely tan. I think I may be running a little lean. I believe my carb has a jet kit in it. Do you know on the air fuel mixture screw which way I would turn it to give it a little more fuel? Im running open pipes, K&N in stock cleaner, and I believe a jet kit. Any help would be appreciated. Thanks
post #13 of 19 (permalink) Old 10-02-2012, 12:50 PM
DBallin69's Avatar
Plug was more of an off white I guess. Bike runs good cruising but seems to sputter a little when taking off from lights or stops even warm. Cold start I pull choke hold, when it starts I hold for maybe 10 seconds and it will idle. I let it warm for a few minutes and from then on when I take off it chugs a little. Seems to be only on the low end. I believe Im getting about 50mpg. Ran out of gas the other day at 162 miles on trip, forgot to turn it on reserve lol.
post #14 of 19 (permalink) Old 10-02-2012, 02:06 PM
DBallin69's Avatar
Hmm not sure never tried it. My choke knob doesnt stay out I have to hold it. Ill prob try a .25 turn on the fuel mixture and see how that works. Alot of times instead of just taking off it start to go, chug, then go lol. Its not horrible but if I can fix it I will.
post #15 of 19 (permalink) Old 10-02-2012, 03:05 PM
DBallin69's Avatar
Ok so I just let the bike warm up a few minutes with no choke. Think I figured out the problem. I had the idle down because I like the way it sounds but when I just turned the idle up some bike revs no problem. Think Im gonna have to deal with the idle a little higher. Dont know how many rpms its at but its not bad at all and def not to high. If I adjust mixture screw a little richer do you think I could idle it back down?
post #16 of 19 (permalink) Old 11-10-2012, 06:07 AM
very nice fab work and i like your thinking of working with what you have. hope i dont incroch but ive been running a 17x5.5 rear Honda CB1100 with disc brakes since i bot mine back in March of this year. I had to fab a bracket to fit the master cylinder to the brake peddle. just thot id show you what ive done maybe give some other ideas if not again sorry
ps please dont mind my terrible welding kinda hard not having the space to do more
Miget is offline
post #17 of 19 (permalink) Old 11-15-2012, 11:53 PM
Bob Myers's Avatar
You want that choke button to stay put wherever you pull it to? Easy, right behind the button is a large plastic nut. Looking at the choke button turn it (the nut) to the right to apply more tension. Left will ease the tension off.
'98 800a w/aluminum wheels/tubeless tires
Iron Butt Ass.#34911
Bob Myers is offline
post #18 of 19 (permalink) Old 07-24-2014, 09:49 PM
CycloneRider's Avatar
I have pieced together a complete Drifter 800 rear disc brake conversion set up to convert a 800 classic or standard to a Drifter.*
I have the rear wheel, rear caliper & rear master cylinder, rear rotor, rear swingarm*
I even have Drifter 800 floor boards/brackets and heel-toe gear shifter.
If anyone is interested send me a private message here...
CycloneRider is offline
post #19 of 19 (permalink) Old 08-14-2016, 01:55 PM
I'm parting out a drifter 800 so lt me know if anyone is interested in these parts.
