97 VN800 Seat Removal - Page 2 - Kawasaki Vulcan Forum : Vulcan Forums
post #11 of 20 (permalink) Old 11-11-2012, 01:53 PM
Bear2123's Avatar
Be certain that the little plastic edge guard is on the tab. A fender scratch could result if you pull downward and back!
Bear2123 is offline
post #12 of 20 (permalink) Old 11-11-2012, 02:17 PM
pacomutt's Avatar
I always slide something like a dollar bill under the tab so it won't scratch the fender when removing the seat.
Ron in Cincinnati
.........Bob Seger
pacomutt is offline
post #13 of 20 (permalink) Old 11-11-2012, 02:23 PM
Bear2123's Avatar
Scratch
Good Idea. I use the back cardboard from a note book.
Bear2123 is offline
post #14 of 20 (permalink) Old 11-11-2012, 06:07 PM
oldrockr's Avatar
On my 800A the bolt takes an 8mm socket but the threaded part is smaller. The parts fiche says 6X14, I guess that's 6mm diameter, 14mm long.
Doug
'96 VN800A
V & H Cruzers
F & S Sissy Bar
Unik Fork Bag
oldrockr is offline
post #15 of 20 (permalink) Old 11-11-2012, 07:38 PM
Bear2123's Avatar
It is a "J" shaped hook under the seat. Pressing down while pulling back will help.
Bear2123 is offline
post #16 of 20 (permalink) Old 11-11-2012, 09:06 PM
XCR600's Avatar
I stand behind mine also ,firmly pull straight back on the pass portion of the seat , it's a tight fit.
95 800A
Memphis shades Demon
Vance & Hines Cruzers
Jardine Rack
Kuryakyn Dually pegs
Baron Risers
Kuryakyn ISO grips
Kuryakyn long horn hwy pegs
Wille&Max saddle bags
XCR600 is offline
post #17 of 20 (permalink) Old 11-11-2012, 09:52 PM
chi
chi's Avatar
I just slap mine at the hump for passenger toward the rear after removing the one bolt at back of seat
Sent from my Nexus S using Motorcycle.com Free App
chi is offline
post #18 of 20 (permalink) Old 11-12-2012, 01:50 PM Thread Starter
I found the best way was to give it a good thump backwards with the heel of my hand . Used the same method to re-seat it when finished . rod
Originally Posted by karstdvr View Post
I can move it side to side so I felt like WD40 wasn't needed. I have pulled pretty hard backward,matter of fact I was afraid I was going to knock the bike down since I pulled so hard. Will give it round 2,round 1 went to the bike.
insnecky is offline
post #19 of 20 (permalink) Old 11-15-2012, 01:30 PM
yamatospecial's Avatar
With the heel of your palm, thump backwards the hump on the pillion rider's part of the seat. I have a luggage rack so I had to push down on the tail.
yamatospecial is offline
post #20 of 20 (permalink) Old 11-15-2012, 01:49 PM
rick's Avatar
Stand beside gas tank, put both palms on the rear part of front seat and lean into it with your body pushing down and back at the same time. The bottom of the seat in the center, 1/2 way back, has 2 hooks that engage a bracket on the fender. The hooks are in line with the strap that goes along the rear protion of the seat. See photo. These are what is holding it.
rick is offline
