chain adjustment - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 4 (permalink) Old 04-01-2012, 08:25 PM Thread Starter
jtaylor's Avatar
chain adjustment
I have a 03 Vulcan 800 classic. What is the proper technique and chain slack for the chain adjustment? I have a repair manual on CD that I cant get to load on my computer and I cant really afford a hard copy right now so your advice on this subject is greatly appreciated.
jtaylor is offline
post #2 of 4 (permalink) Old 04-01-2012, 09:04 PM
kfolse107's Avatar
I'm pretty sure that no matter what bike you have, it should be between 1" and 1.4" measured halfway between the sprockets.
I care more about SPG (smiles per gallon)
than MPG (miles per gallon)
2009 Vulcan 500 LTD
Scootworks Risers
Slipstreamer Enterprise windshield
Protac driver backrest
Rumble Road speaker system
River Road saddlebags
Priority Plus tail light module
Kuryakyn chrome accessory plug
Kuryakyn ISO grips (6235)with Throttle Boss
JTF512 17tooth sprocket
"Manuel/Vicente" custom engine guard
Hardley highway pegs (freebies)
kfolse107 is offline
post #3 of 4 (permalink) Old 04-02-2012, 06:44 AM
I think kfolse is correct in the amount of slack. If you have done this on other bikes you can skip this rest of this email. If not, remember that it is just as important that you keep the chain running straight on the sprockets as it is to maintain the proper tension. Make equal adjustments on both sides of the rear axle, Eyeball the chain over the sprockets, it should be straight, running parallel with the sides of the sprocket.
t4kne is offline
post #4 of 4 (permalink) Old 04-02-2012, 12:47 PM
Yep....25mm - 35mm slack midway between the sprockets
davemn is offline
