Was trying to install a new light set when I shorted out the left front turn signal. I replaced the fuse but now I have on electrical at all except the rear tail light.( No horn , turn signals , no starter)
I check the main 30amp fuse and it was still good..
The only fuse that controls all the things he says doesnt work is the main fuse. Does the tail light go out when the ignition is on and the horn is pressed?
Alternatively, he's pulled out a lot of wiring in the headlamp shell.
I will start by wiping the egg off my face..
I stated that I was installing a new light set when I shorted out the turn signal fuse. well what I forgot and forgot to sat is there is not a lot of room with all the wires and cannon plugs, so I unplug them..
Then when I try the switches they did not work.. All well plug them back in and things work fine.
So thanks to every one who responded to my SOS:smile
Related Threads
Kawasaki Vulcan Forum
712.7K posts
67.9K members
Since 2008
