I have read in a few posts that some have had their petcock to continue leaking even after repairing with a rebuild kit.
Therefore, I'd like to share my recent experience in case it might be of help to someone.
I noticed last week that the petcock on my '05 800 Classic had begun to drip from the nipple 1 drop approximately every 4-5 seconds.
I figured since this bike had been sitting up for several months before I got it, the diaphragm may be rotted out.
Since petcocks are so expensive (for what they do), I decided to purchase the rebuild kit (K&L 18-5023) and give it a shot.
Upon tear-down, to my surprise I noticed o-rings and diaphragms were still in really good shape. Therefore, I seriously doubted that the diaphragm itself was the problem. However, since I had bought the kit I figured I would go ahead and install it anyway.
This petcock (in the "on or Reserve" position) allows fuel to flow to the carb when the engine is running because a vacuum is created which sucks the spring-loaded diaphragm away from the inlet. When the engine stops, the spring causes the diaphragm to seal the inlet shut.
Before installing the new kit, I noticed the new spring was just a tad longer than the old spring. I took the new spring and carefully stretched it as much as I could without damaging it (approx. twice it's original size), put everything back together and it works like new.
I will try to update this post weekly to verify that this fix holds up for the long haul, but so far I'm grinning again.
