make forward control extensions?? vulcan 800 - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 39 (permalink) Old 07-23-2011, 06:26 PM Thread Starter
i have a 98 vulcan 800. and need the foot controls out farther. i know its been done and want to know the dimensions of the extensions that people make for these bikes and how to make them or what to use? some pointers would be helpful.
karnsy vn800 is offline
post #2 of 39 (permalink) Old 07-24-2011, 03:21 AM
if you know how to weld you can make your own
extensions are 4", 6" or 8"
05 Vulcan Mean Streak, Vance & Hines Big Shots, Power Commander, Smoked Front lenses, 65 tbird rear signals 8000K HIDs, LED everything, black bullet headlight, teardrop mirrors, Barons Big Air kit, various powdercoated parts
JRod is offline
post #3 of 39 (permalink) Old 07-24-2011, 04:07 PM
I think you could make them without welding, all you would need is two pieces of steel the same thickness, drill two holes that match up to the mounting bolts, two more to match the controls, bolt the two pieces to the original controls, bolt them to the mounting bolts. The toughest part will be making some sort of hook up for the brake cable for the rear. I am still working on that part. As soon as I get that figured out that is how I will move mine, 3 inches forward, 1 inch higher.
BaddaBing is offline
post #4 of 39 (permalink) Old 07-24-2011, 06:00 PM
controls
You need to cut the tab off for the brake cable an weld it on to new plates i know i just made them
racerx928 is offline
post #5 of 39 (permalink) Old 07-24-2011, 11:25 PM
matt36567's Avatar
i moved mine forward 2 inches. on the left side I used a meteric coupling nut and bolt to extend on the right side I ran the brake cable over the frame instead of below it.
vn800a8
memphis shades windshield
custom luggage rack
kuryakyn flame grips
drilled pipes
debadged
matt36567 is offline
post #6 of 39 (permalink) Old 08-18-2011, 03:55 AM
Its piss easy to do I have made for various bikes already, each is different and have there own unique solutions. My advice is make a rough mock up from wood with all the holes in the right place. Then make out of steel or aluminum which is what I use.
Slash is offline
post #7 of 39 (permalink) Old 08-18-2011, 08:28 AM
Looks like lots of people have done it. How about posting a pic of your mods? I'm not real happy with the stock position and would like to see others ideas too.
t4kne is offline
post #8 of 39 (permalink) Old 08-18-2011, 09:05 AM
I second t4kne. If anyone has pics, I'd love to see them.
kreaves is offline
post #9 of 39 (permalink) Old 08-24-2011, 03:52 PM
Banned
i would say they don't
i'm starting to make some that match the floor boards that came on the 800 classic i just added to the stable...
whiskyrockr is offline
post #10 of 39 (permalink) Old 12-20-2011, 04:20 PM
Yeah, I'd love to see pictures too!
bharris42 is offline
