sticky/stuck clutch - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 5 (permalink) Old 12-05-2012, 02:55 PM Thread Starter
sticky/stuck clutch
Has anyone had problems with the wet clutch on their voyagers? Service my ride every 10k (or sooner if going on an extended trip) and while putting my ride to rest for the winter have great difficulty in getting it out of gear. clutch in...first gear....release brake....idle foreward with clutch still depressed.
Anyadvice or words of wisdom? Oil is kawasaki 100% synthetic. Bike has 70k(about 45000m) and ridden like a cruiser should.
Thanks in advance
Manitoba Kevin
kmac1 is offline
post #2 of 5 (permalink) Old 12-05-2012, 04:24 PM
MAESTRO-SPRF's Avatar
The problem will be with the clutch fluid due to its degridation over time and the development of air contamination from vapourized water. From past experiences with hydraulic systems I would recommend changing and bleeding your hydraulic systems while winterizing you steed as DOT3/4 will absorb moisture(hygroscopic) causing all kinds of performance issues.This is just my 2c worth and I hope it helps.
WHEN ALL ELSE FAILS, LOWER YOUR STANDARDS...
-2011 VAQUERO(RUBY)
-V&H SLIP ONS
-PC V INSTALLED AND TUNED (sheek map slightly modified)
-THUNDER MFG. HURRICAINE INTAKE.(lost 3 pairs of pants already)
-LOTS OF LED LIGHTS TO BE VISABLE AT NIGHT (MULTI COLOUR WITH PSYCHODELIC OPTIONS)
-SCYTHE MIRRORS
-I POD ADAPTER
-NAUTILUS AIR HORN(WHAT DID YOU SAY???)
-MANY MORE MODS TO COME.....
MAESTRO-SPRF is offline
post #3 of 5 (permalink) Old 12-05-2012, 04:58 PM
davemc's Avatar
I would tend to agree with Maestro-sprf. Maybe the clutch plates are not actually stuck, but instead the clutch is not completely disengaging when you pull on the lever. I would suggest to squeeze the lever several times and see if that eliminates the problem.
2009 Vulcan Voyager, Wolo Bad Boy air horn, Kuryakyn ISO grips with contoured throttle boss, Kuryakyn Adjustable Floorboard Cruise Peg mounts with pegs, Cobra Tri-Oval exhaust, K&N air filter, temperature dipstick, saddlebag rails, Superbright trunk light flasher.
davemc is offline
post #4 of 5 (permalink) Old 12-08-2012, 03:01 PM Thread Starter
clutch
thanks guys....will try both and if not resolved, may have to get it to the dealer
kmac1 is offline
post #5 of 5 (permalink) Old 12-08-2012, 03:14 PM
Comanche's Avatar
Thanks in advance
Manitoba Kevin
Make sure to check your free play limits too while you're at it.
Comanche is offline
