Question on De-baffling the pipes on a Voyager - Page 4 - Kawasaki Vulcan Forum : Vulcan Forums
post #31 of 40 (permalink) Old 12-27-2012, 09:06 AM
Bubba in TX's Avatar
One thing I forgot... moving the mufflers around a lot could have loosened your muffler gaskets as they are somewhat fragile. But when my Venture gaskets made noise it was like a chirp that moaned on a violin string.
Try tightening the gaskets some. Also check the exhaust gaskets at the heads. Those copper gaskets can leak also when disturbed.
Bubba in TX
2011 Voyager "Betty Clunker"
Some people collect T-shirts
I actually ride
Voyager 1700 owners...
WRAP your pipes....
You will be glad you did...
U.S.A.F. Retired
Nye County Nevada
Motor Officer Retired
Blue Knights Texas 43
Bubba in TX is offline
post #32 of 40 (permalink) Old 12-27-2012, 09:26 AM Thread Starter
fammdwMike's Avatar
Please forgive my ignorance, but I've never removed a set of OEM pipes from a bike. Can you tell me what gaskets you are referring to and where I can locate them?
Mike Williams
Wichita, Kansas
2012 Kawasaki Vulcan 1700 Voyager
2009 Yamaha FJR1300
2006 Kawasaki Vulcan 1600 Nomad
2002 Yamaha V-Star 1100 Custom
1989 Yamaha Virago 750
fammdwMike is offline
post #33 of 40 (permalink) Old 12-29-2012, 07:15 PM
Aussie.Nomad's Avatar
Year/Make/Model: 2010 Vulcan Nomad
Color: Black & silver
Originally Posted by fammdwMike View Post
Okay... I drilled out both of the rear baffle plates on each of the mufflers. I had to buy another 12" arbor extension because I was bottoming out the drill trying to reach the second plate with only one.
Question: Has anyone that has done this experienced a chirping sound on final decel when you roll off the throttle? When I roll on the throttle standing beside the bike, I hear some strange chirping like sound just as the pipes settle down back to idle. For the life of me, I can't tell if this sound is coming from the pipes themselves or I have a mount rattling somewhere near the rear of the bike. Never heard this sound before drilling out the baffle plates.
Did'nt leave any metal in the pipes?
Aussie.Nomad is offline
post #34 of 40 (permalink) Old 12-29-2012, 07:21 PM
Damo222's Avatar
Gaskets are where the mufflers join the header pipes
Damo222 is offline
post #35 of 40 (permalink) Old 12-29-2012, 08:33 PM Thread Starter
fammdwMike's Avatar
Both the rear baffles came out in the hole saw. The baffles right behind the cats did not. This is typical from what I understand from others that have drilled them out.
Mike Williams
Wichita, Kansas
2009 Yamaha FJR1300
post #36 of 40 (permalink) Old 02-07-2013, 12:53 AM
Still considering debaffling the Nomad, have found a diagram of the mufflers, will try & put it up her, bear with me, but am wondering about taking out the cats as well.
Will there be any problems, will I need to get a fuel procesor, not interested in these if not needed.
Thanks in advancer
post #37 of 40 (permalink) Old 02-07-2013, 04:23 AM
rick's Avatar
FammdwMike, did you isolate that chirpping sound? Just had a thought. On my brother-in-las 1100 V-Star with open shotgun pipes, I would hear a low wistle when he was off the throttle at certain speeds. Have heard it on my 800 classic also a time or to. I beleive it the air going through the open pipes, a side effect of less restriction maybe. Almost like a low pressure air line that is open. Any thoughts?
2005 800 classic
2012 Voyager ABS
rick is offline
post #38 of 40 (permalink) Old 02-07-2013, 09:00 AM Thread Starter
fammdwMike's Avatar
Never did figure out exactly what it was. Got a great deal on a used set of V&Hs. Put those pipes on - problem solved.
I'll say this about debaffled pipes... There is definately an improvement in sound over stock, but it does not hold a candle to the low rumble and tone of aftermarket slip-ons. I'm glad I made the investment in the V&H pipes.
Mike Williams
Wichita, Kansas
2009 Yamaha FJR1300
post #39 of 40 (permalink) Old 06-25-2015, 10:52 AM
Cspradlin's Avatar
This thread is bullshit. It wouldn't have been hard to post a few pics. All you find on YouTube is 900 and 1600 videos. So know I have a worthless exhaust because I did it the way they did. The original threads don't say removing the baffle plates. It says removing the baffles. There is a big difference in those 2 statements. I have been working for 6 hours to get these baffles out and now I see that no one is actually removing the baffles. Guess I'll drive my truck for a few months till I can get some pipes.
Cspradlin is offline
post #40 of 40 (permalink) Old 07-11-2015, 06:16 PM
Just one more exhaust hypothosis
Please know that I'm as cheap as the come(I rode a KLR for ten years) so here's my question:
If you debaffle the stock pipe do you open it up enough to have enough flow to remove the left side pipe? Then I could have my 2-1 pipe without the cost. Just a thought.
thanks in advance for your consideration!!
Goofy1 is offline
