Brake pedal slashing re-visited..... - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 4 (permalink) Old 11-30-2012, 11:38 PM Thread Starter
Bubba in TX's Avatar
It has been a while since I did the post on whittling that too wide Voyager brake pedal down to a reasonable size for us floorboard acreage impaired guys. Otherwise known as the non dainty footed boys.
Anyway, I took the break pedal pad assembly off the pedal arm bu removing the pin and spring. Cut the pedal a little over the half way mark right at the first pad mounting bolt. I them used my medium bench top belt sander to round off the cut edge to make it look better. You will notice some air gaps now that some of the metal under the pad is gone. I used black epoxy and filled in the holes. After that was set and dry, sanded them smooth again and put it all back on the Voyager. I like my pegs as low as the boards and now I have room between the peg and the brake pedal for my clod hoppers.
See pics..
Bubba in TX
2011 Voyager "Betty Clunker"
Some people collect T-shirts
I actually ride
Voyager 1700 owners...
WRAP your pipes....
You will be glad you did...
U.S.A.F. Retired
Nye County Nevada
Motor Officer Retired
Blue Knights Texas 43
Bubba in TX is offline
post #2 of 4 (permalink) Old 12-01-2012, 06:26 PM
R_W_B's Avatar
Thanks for posting the pics Bubba. You did a nice job on the pedal mod. Someday I plan to do the exact same thing. I have a size 12 American and size 13 for Walmart China made boots, the brake pedal does impede into my desired space.
R_W_B is offline
post #3 of 4 (permalink) Old 12-02-2012, 08:47 PM
Netnorske's Avatar
I did something very similar...I used a band saw to make the intial cut, then cut an additional half an inch off the metal plate so that the end of the cut plate would be more recessed under the rubber piece and not show so much. I then used a small cut piece of chrome door molding to cover the cut edges of the pedal plate...and sprayed the end of the rubber pad with some rattlecan stuff that is like the stuff they spray in truck bedliners. That covered up the metal inside the rubber from showing too badly. The rest was just shaping the end of the rubber to look decent. I used a grinding wheel at work for that.
I like to ride with my heel on the floorboard and my toe on the highway peg, but the brake pedal was just in the way. This was a great fix....
ID:	14458   Click image for larger version
ID:	14459   Click image for larger version
ID:	14460   Click image for larger version
ID:	14461   Click image for larger version
VBA #0691 VROC #31307
2013 Victory Cross Country Tour
2012 Black/Gray Voyager
2008 Blue/Silver Nomad
"Growing old is mandatory,
but growing up is optional."
Netnorske is offline
post #4 of 4 (permalink) Old 12-02-2012, 11:24 PM Thread Starter
Yep... I like my heel on the board and my toes on the pegs. Lower the better for me and my legs...
On my Venture I could hang the back of my feet lower than the boards...
Bubba in TX
I actually ride
WRAP your pipes....
U.S.A.F. Retired
Nye County Nevada
