Noise from the rear end - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 5 (permalink) Old 11-29-2012, 06:36 PM Thread Starter
dixie20j's Avatar
Got a squeak coming from the rear end. I have had the bel adjusted by a local shop and the belt did not show any sogns of wear, the tire is not rubbing any wear and the noise is made on both concrete and grass. Based on what I've rear on here before I'm thinking one of the bearing may be going bad. Any suggestion for what I may need to look into or have my shop look into under the warranty?
Blue Knights AL III - V.P.
dixie20j is offline
post #2 of 5 (permalink) Old 11-29-2012, 08:39 PM
MAESTRO-SPRF's Avatar
A quick test for belt noise is to rub a candle against the teeth on the belt take it for a little spin then check for the noise. If the noise is gone it was your belt if not you will have to check further.My VAQ makes the same noise when I am moving the bike around slowly which is coming from my belt.
WHEN ALL ELSE FAILS, LOWER YOUR STANDARDS...
-2011 VAQUERO(RUBY)
-V&H SLIP ONS
-PC V INSTALLED AND TUNED (sheek map slightly modified)
-THUNDER MFG. HURRICAINE INTAKE.(lost 3 pairs of pants already)
-LOTS OF LED LIGHTS TO BE VISABLE AT NIGHT (MULTI COLOUR WITH PSYCHODELIC OPTIONS)
-SCYTHE MIRRORS
-I POD ADAPTER
-NAUTILUS AIR HORN(WHAT DID YOU SAY???)
-MANY MORE MODS TO COME.....
MAESTRO-SPRF is offline
post #3 of 5 (permalink) Old 11-30-2012, 12:39 AM
Aussie.Nomad's Avatar
Year/Make/Model: 2010 Vulcan Nomad
Color: Black & silver
Spray some silica (electrical grease) spray on the belt or even some wd40
Aussie.Nomad is offline
post #4 of 5 (permalink) Old 11-30-2012, 12:37 PM
BeanO works for me...
Lunatic is offline
post #5 of 5 (permalink) Old 12-02-2012, 01:36 PM
JDB
I had a squeak from the rear of mine. After about an hour of searching I found that it was a missing screw on the inside of the finder where the lower piece and the upper piece hook together with a bracket. The plastic was rubbing on the bracket causing a sqweak. Put the screw in no sqweak
JDB is offline
