Vaquero, Wrapping Pipes - Page 2 - Kawasaki Vulcan Forum : Vulcan Forums
post #11 of 19 (permalink) Old 11-29-2012, 08:48 AM Thread Starter
Thanks again for all the tips. I was personally going to just stop by the local auto parts store for the supplies to do this. Any reason -not- to?
Lunatic is offline
post #12 of 19 (permalink) Old 11-29-2012, 09:44 AM
cruiser900's Avatar
I used "inferno heat wrap" from Heatshield Products on EBay. Don't skimp on quality. I used 1 inch as you can get a tighter radius and overlap. My two pipes took nearly 100 feet and they are double wrapped.
cruiser900 is offline
post #13 of 19 (permalink) Old 11-29-2012, 10:14 AM Thread Starter
Hmm. I agree, quality is important. Off to Ebay I go.
Lunatic is offline
post #14 of 19 (permalink) Old 11-29-2012, 01:32 PM
davidsheek's Avatar
Not really, there's just different types too choose from. The auto parts will probably be $50 for the same 50ft.
davidsheek is online now
post #15 of 19 (permalink) Old 05-05-2013, 05:59 PM
element80's Avatar
from lava wrap instructions
6. It is important to start on side closest to exhaust port (closest to engine), wrapping down the system
towards the exhaust tip.
7. Make an initial wrap around the pipe and secure end with Thermal-Tie™ (Figure 4) or hose clamp.
8. After securing end, continue to wrap around pipe, using ¼” overlap with each pass (Figure 2) and
keeping tension on the exhaust wrap.
traded the vaquero for a streetglide
element80 is offline
post #16 of 19 (permalink) Old 05-05-2013, 08:09 PM
IL Vaquero's Avatar
Hey Trey,
Hows it going man haven't heard from you in a while. I haven't been on here in a while hows the bike work for you. Mine is back at dealer getting the cruise fixed. And Im getting screwed by the dealer as usual I will pm you and tell myou all about it. two weeks to change the right switch housing calls for.8 hours labor told me had to take faring off to wire in the switch. Called another dealer they lafed said dont have to take faring off to change housing. Man they hate working on my bike so it will be the last time glad you got your pipe wraped realy helped my bike. And cut down on lifter and valve noise got the air leak fixed right and put the pcv/ign on. Now I want to take to so guys named two brs custom exhaust to get the cross over cut and made into true duels. Hope it sounds better but got to get it redynoed. My e-mail is bskz4@frontier.com lets talk some time sound good. B Cope.
Only a motorcycle rider knows why a dog sticks he head out the car window. Enjoy life.
IL Vaquero is offline
post #17 of 19 (permalink) Old 05-20-2013, 06:25 PM
element80's Avatar
Originally Posted by IL Vaquero View Post
Hey Trey,
dang BCOPE they are killing you! I am going to wrap my pipes this weekend, and flush the RAD and replace with engine ice, and install a fan switch like RACNRAY did...planning on selling the PCV and trying the one with ignition as well....also think Ill pull the throttle body off again and use some sealer or gasket maker on it
post #18 of 19 (permalink) Old 05-31-2013, 12:10 AM
so wrap the exhaust, engine ice and whats up with the fan?
Current: 2011 Vaquero, 2005 zx-10, 2003 Yamaha R6
Past: 2008 yamaha raider, 2007 zx-14, 2000 zx-9, 1994 zx7RR
zx10duran is offline
post #19 of 19 (permalink) Old 05-31-2013, 12:19 AM
element80's Avatar
Got the pipes wrapped and coolant dumped. Flushed the old stuff Used distiller water but never cranked the bike. It had been sitting cold for at least a day. Y'all think there was enough eg lft in the system to cause trouble with the engine ice?
Well I'm off tomorrow and plan to get the heat shields back on and should get the new pcv with ignition tomorrow
