Instrument cluster gremlins - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 6 (permalink) Old 11-15-2012, 08:21 AM Thread Starter
RogerE's Avatar
I ride a 2009 Vulcan Nomad with 19,000 miles on the odometer. Lately strange things have been happening with the instrument cluster. The trip odometers will both spontaneously reset themselves to zero at the same time, usually after about 100 miles of travel. The clock is also changing itself without any pattern that I have been able to discern.
If you have had this problem and know what is causing it, or if you have a theory, please let me know. Thanks!
Patriot Guard Rider
Taps Bugler - Bugles Across America
Sons of the American Legion
I spent most of my money on wine, women and motorcycles. The rest I wasted.
RogerE is offline
post #2 of 6 (permalink) Old 11-15-2012, 08:35 AM
Dan66's Avatar
Since you didn't list it, I would assume the bike is starting OK which discounts the battery. If you are experiencing no other problems then I would begin investigation at the cluster powering/grounding.
The cluster is not the only thing powered with the keyswitch so if no other problems I think it is isolated to your cluster.
A temporary ground will help identify that problem and if problems with power disconnecting you likely have a loose wire/connection somewhere and this is different troubleshooting altogether.
Dan66 is offline
post #3 of 6 (permalink) Old 11-15-2012, 08:35 AM
twowheeladdict's Avatar
The right handlebar control is what affects those settings. I would start there and see if spraying some contact cleaner in there fixes your issue. The bike ever sit out in a driving rain that was going from the rear of the bike? or did you spray water at those controls while washing the bike?
twowheeladdict is offline
post #4 of 6 (permalink) Old 11-15-2012, 08:46 AM Thread Starter
RogerE's Avatar
Thanks for your thoughts. The bike starts an runs fine. I agree with your thinking that the problem is probably in the cluster.
Patriot Guard Rider
RogerE is offline
post #5 of 6 (permalink) Old 11-15-2012, 08:49 AM Thread Starter
RogerE's Avatar
The bike is and always has been garaged. I have never been shy about riding in the rain, and rode in a lot of heavy rain and washed the bike many times over the past three years without any trouble. This condition just started recently. I will pick up some contact cleaner and spray the switches - this is an easy thing to do first. Thanks!
Patriot Guard Rider
RogerE is offline
post #6 of 6 (permalink) Old 03-17-2013, 08:46 AM Thread Starter
RogerE's Avatar
Just an update in case anyone else experiences this problem. I recently replaced the battery (it was the original and was four years old). The bike was still starting but was cranking slow and I could tell the battery was on the way out. With the new battery the problems with my instrument cluster went away.
Patriot Guard Rider
RogerE is offline
