Question for 1700 owners - Page 2 - Kawasaki Vulcan Forum : Vulcan Forums
post #11 of 22 (permalink) Old 10-30-2012, 09:33 PM Thread Starter
Send a message via AIM to tmanv2krider
Don't drink, so I know for sure that's not an issue. I'll hopefully get some video sometime soon.
1996 Harley Davidson FXDS with a lot of stuff. Yes, it's fast, yes it will pull the front tire in 1-3rd. No it's not a stock evo.
2011 Vulcan 1700 Vaquero
tmanv2krider is offline
post #12 of 22 (permalink) Old 10-31-2012, 07:50 PM
Damo222's Avatar
Yep i have the same noise on my Nomad.
Sounds to me like a bearing knock in the bottom end, bike seems to run ok its got 12000k's on it now. I have my suspicions that it may be fuel knock when you blip the throttle really quickly. Due to the built in delay these bikes seem to have. I gave mine the "throttle mod" treatment and seems to have reduced the incidence.
My bike has done it since new, but as i said it seems to run ok.
Damo222 is offline
post #13 of 22 (permalink) Old 11-01-2012, 07:31 AM
Yeah, my 1700 classic LT has had that internal knock on occasion since day one. 6000 miles on it, no problems so far.
vulcan 1700 is offline
post #14 of 22 (permalink) Old 11-01-2012, 04:51 PM
R_W_B's Avatar
Don't know what kind of Knock you are talking about.
When you blip the throttle, does the engine stutter and hesitate ?
If so is this when you hear the clunk or knock ?
If you answer yes to both the above then, yes I have the same thing on my 2011 Nomad. It got worse when I put the throttle mod on it, prior to the throttle mod it mostly did nothing when I blipped the throttle, no rpm gain, just kinda nothing. The throttle lag is the result of Kawa's electronic throttle.
I have to gradually increase rpms before I blip the throttle or else I get a very detectable knock. Evidently the ECM is not able to deal with a fast increase of throttle from idle (resulting from the throttle mod).
R_W_B is offline
post #15 of 22 (permalink) Old 11-01-2012, 06:14 PM
Timberwolf2012's Avatar
clunk
My 2010 Nomad does the same thing. Bear in mind those are large pistons slinging around. Because of the single pin crank design of this v-twin, if you goose the throttle from idle, you will get a "slap" from the engine. I don't think it is anything to worry about.
Timberwolf2012 is offline
post #16 of 22 (permalink) Old 11-01-2012, 06:44 PM
R_W_B's Avatar
I'm not so sure on that Timberwolf (with all due respect). My previous Harley had a single pin crank (all Vtwins do) and I never got anything like that. I think it's the ECM timing and reactions to the throttle.
I try not to blip my Nomad since I'm afraid it's a pre-ingition knock. In normal engine (that's not worn out) there should be no piston slap or rod beaing knock.
R_W_B is offline
post #17 of 22 (permalink) Old 11-02-2012, 04:25 AM
Damo222's Avatar
RWB, i think we're all on the same page with this. I reckon you're spot on, i couldnt place what the sound reminded me of till you said PRE IGNITION knock.
Thats what it would be.
If the bike is idleing really low its more common.
Damo222 is offline
post #18 of 22 (permalink) Old 11-02-2012, 03:42 PM
knock
Ya it really depends on exactly what the noise is, hard to tell via a forum . My noise is not pinging, its just a lot of metal to get moving in short order when you goose it from idle. I was just offering an idea, opinion, I'm no expert
post #19 of 22 (permalink) Old 11-02-2012, 07:55 PM
R_W_B's Avatar
I've been concentrating on riding for while and my work schedule has been crunched. Soon I plan to install my new PCV w/Ignition. I don't have anything on the bike but Cobra Tri-Ovals, so I can't put in David's full blown (big air) map. But I'm gonna see if the Power Commander slip on map download takes care of this situation.
R_W_B is offline
post #20 of 22 (permalink) Old 11-03-2012, 01:26 AM
Damo222's Avatar
The noise reminds me of that pre ignition knock i used to get on my old cars when i turned them off and they kept running for a few seconds, like a clunking knock.
Damo222 is offline
