Cleaned up my butt. - Page 3 - Kawasaki Vulcan Forum : Vulcan Forums
post #21 of 30 (permalink) Old 11-02-2012, 01:40 PM
Einstein's Avatar
So a thought popped in my head "why did the volts come up - instead of + when I was testing the circuit"
So I switched leads and it all works great, I think my wiring harness is backwards
Philip "Einstein" Darling
2013 BMW K1600GTL
<SOLD>2011 Vulcan Vaquero "La Belleza Negra"
<SOLD> 2004 BobRR
VROC #9925
Dinosaur R/G #128
Phoenix, AZ
Einstein is offline
post #22 of 30 (permalink) Old 11-02-2012, 02:43 PM
RACNRAY's Avatar
PHILLIP...are those some kind of vinyl covers on your bags? They look nice.
"TRUE HAPPINESS IS IN THE HEART,NOT IN THE OUTSIDE FIXES!!"
WITH OVER 39 YEARS AS A MOTORCYCLE TECHNICIAN/HI-PO SHOP OWNER I AM A PURVEYOR OF FACT NOT FICTION!
"WE LIVE OUR LIVES IN CHAINS NEVER KNOWING WE HAD THE KEY"
RACNRAY is offline
post #23 of 30 (permalink) Old 11-02-2012, 04:16 PM
Einstein's Avatar
Yeah Ray I got those as a Xmas present from PH Customs but unfortunately they don't make them anymore
2013 BMW K1600GTL
<SOLD> 2004 BobRR
VROC #9925
Dinosaur R/G #128
Phoenix, AZ
Einstein is offline
post #24 of 30 (permalink) Old 11-02-2012, 07:09 PM
rick's Avatar
Fast95, I understand the resisters, but why the diodes?
rick is online now
post #25 of 30 (permalink) Old 11-02-2012, 07:30 PM
Einstein's Avatar
Smile Failure Was Not An Option
So some wiring mods, some solder, shrink tubing and the Load Equalizer and success is at hand. My new rear End is finished!
ID:	14074   Click image for larger version
ID:	14075   Click image for larger version
2013 BMW K1600GTL
<SOLD> 2004 BobRR
VROC #9925
Dinosaur R/G #128
Phoenix, AZ
Einstein is offline
post #26 of 30 (permalink) Old 11-03-2012, 03:43 AM
carguy50's Avatar
looks clean. great job
carguy50 is offline
post #27 of 30 (permalink) Old 05-30-2013, 11:53 PM
c_law23's Avatar
This electrical talk is above my paygrade. If I just want LED running lights and signals, I just need to tap into the the existing signal wiring right? Just an easy splice and done?
Also Einstein, that plate frame looks amazing... a little too much scratch for me to justify to the boss though!
Chris
Black 2011 Vaquero 1700
Black 2007 900 Custom (sold)
VBA #02389
VROC #24810
c_law23 is offline
post #28 of 30 (permalink) Old 05-31-2013, 06:51 AM
Bubba in TX's Avatar
Depends on the LED you purchased and if you want it to do double duty like stop/turn and running light. If you only want it for single duty for stop light or running light OK. With the resisters and diode you can make a LED do double duty.
But for turn signals........you will need a load compensator or light controller, or a flasher that uses a relay to flash instead of the bi-metallic strip to make it flash, otherwise your turn signal lights will blink really fast..... I am sure you have seen cars and motorcycles both do that.
Bubba in TX
2011 Voyager "Betty Clunker"
Some people collect T-shirts
I actually ride
Voyager 1700 owners...
WRAP your pipes....
You will be glad you did...
U.S.A.F. Retired
Nye County Nevada
Motor Officer Retired
Blue Knights Texas 43
Bubba in TX is offline
post #29 of 30 (permalink) Old 05-31-2013, 09:26 AM
c_law23's Avatar
I have, so if I just run a "run, brake and turn controller" or whatever they are called in the mix, all will be well then? Thanks
Chris
VBA #02389
VROC #24810
c_law23 is offline
post #30 of 30 (permalink) Old 07-11-2013, 09:48 PM
Looks great, thinking about this project also.
tin_star is offline
