Auto Tune and O2 Sensor Location - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 47 (permalink) Old 06-19-2012, 07:42 PM Thread Starter
Combat72's Avatar
Ok, about to pull the trigger on a PCV with Auto Tune. Curious about the location of the O2 Sensor. I know the stock location is in the right side muffler. I'm considering putting it right after where the exhaust manifolds join. That way if/when i install slip-ons I won't have any issue with having to put a bung in the new slip-on. Has anyone done this? Any issues? Is there a pic available showing it?
Thanks,
Frank
2010 Voyager/ Metallic Diablo Black/Metallic Imperial Red
1972 Norton Commando - Yellow
PCV(Fuel & Ignition) With Autotune
Gear Advance Fuel & Ignition Mapping
Cobra 4' Scalloped Tip Slip-Ons
Wrapped Exhaust Manifold
Kuryakyn ISO Grips with RacnRay Mod
Kuryakyn Bar End weights
Ultimate Mid-Rider
Polk Audio DB521 speakers
K&N Air Filter
Rear Speakers
Mirror Risers
iPod Adapter
Combat72 is offline
post #2 of 47 (permalink) Old 06-19-2012, 09:07 PM
rusty360's Avatar
I may be wrong but I do not think they have o2 sensors except maybe California models. I'm sure somebody will correct me if I'm wrong.
2014 Honda Gold Wing
2011 Vaquero sold
2009 900lt sold
rusty360 is offline
post #3 of 47 (permalink) Old 06-19-2012, 09:19 PM Thread Starter
Combat72's Avatar
Rusty360,
You are correct, the CA, European and Aus models are the ones with the O2 sensor. I should have worded it better in my original post. The location of the O2 sensor on those bikes is in the right muffler.
Thanks,
Frank
Ultimate Mid-Rider
K&N Air Filter
Rear Speakers
Mirror Risers
iPod Adapter
Combat72 is offline
post #4 of 47 (permalink) Old 06-19-2012, 09:26 PM
rusty360's Avatar
So your installing a o2 sensor on your bike for the PVC?
2011 Vaquero sold
2009 900lt sold
rusty360 is offline
post #5 of 47 (permalink) Old 06-19-2012, 09:33 PM Thread Starter
Combat72's Avatar
Rusty360,
That is correct. The Autotune comes with one O2 sensor for the VV. The Autotune then connects to the PCV and will adjust the fuel table accordingly. Trying to determine the best location for the O2 sensor.
Frank
Ultimate Mid-Rider
K&N Air Filter
Rear Speakers
Mirror Risers
iPod Adapter
Combat72 is offline
post #6 of 47 (permalink) Old 06-19-2012, 11:04 PM
new kawi rider's Avatar
Does the auto tune adjust the fuel for you or does it make recomendations to you and you have to hook up to the pc and change it yourself??
2010 Voyager
Scootworks 2 inch fat risers
vance&Hines slipons
Mustang Wide Touring studded
PCV
Michelin commander 2
Ipod adapter
Titanium header wrap
8 to 12.5 inch bagger windshield
Iso grips with Rays throttle mod
Chrome rear floor board covers
Kams Kit
new kawi rider is offline
post #7 of 47 (permalink) Old 06-19-2012, 11:23 PM Thread Starter
Combat72's Avatar
New Kaw Rider,
You start off with a base map. Dyno Jet has some on their website and others on the forum have been sharing theirs. The autotune will then make adjustments and you can choose to save them or not. You can actually save two maps on the PCV, one could be for performance and one for better fuel economy. See links below:
PCV (Fuel & Ignition)
http://www.powercommander.com/powerc...dl=290&yr=2010
Autotune
http://www.powercommander.com/powerc..._autotune.aspx
Plenty of post on here regarding the Power Commander. Maybe those using one will chime in.
Frank
Ultimate Mid-Rider
K&N Air Filter
Rear Speakers
Mirror Risers
iPod Adapter
Combat72 is offline
post #8 of 47 (permalink) Old 06-20-2012, 01:08 AM
I'm running the PCV and Autotune setup on my Vaquero. The bike has never ran better and fuel mileage is very good. Should have done this a year ago!
Jim "AzCruizer" Lohman
Gilbert, AZ
2013 Vision Tour
2011 Vaquero-sold
AzCruizer is offline
post #9 of 47 (permalink) Old 06-20-2012, 07:55 AM Thread Starter
Combat72's Avatar
AzCruiser.
Where did you put the O2 sensor? Do you have a pic and would put it in the same place if you could do it over again?
Frank
Ultimate Mid-Rider
K&N Air Filter
Rear Speakers
Mirror Risers
iPod Adapter
Combat72 is offline
post #10 of 47 (permalink) Old 06-20-2012, 08:11 AM
captj3's Avatar
Combat I would put the sensor at the crossover or a little before it in the exhaust. This way it would read from both cylinders. This way if you decided to install slip-ons it wouldn't get in the way. Doesn't power commander show you where to locate it in the install instructions?
2012 Vaquero Candy Lime Green/Black
1700 Nomad (Deceased)
Cobra Tri-Oval Exhaust
Racnrays Invention (Throttle Mod)
Ivan's Flash
Thunder Tornado Air Kit
captj3 is online now
