Michelin Commander II - Page 17 - Kawasaki Vulcan Forum : Vulcan Forums
post #161 of 208 (permalink) Old 08-08-2012, 07:43 PM
BOTM Winner, April 2013
tstorey823's Avatar
Originally Posted by hueygunner View Post
Looking for info. I have a friend with a Harley Limited and he had the catalytic
converter removed. He says it runs cooler and it does sound pretty good. I know
V&H and Cobra have no converters. Does anyone know if there is a header
pipe (without the converter) that matches up with the stock mufflers. I know that
without the converter the pipes would run cooler. That converter in there is like
a hot brick!
State of Confusion! I somehow thought this thread was titled "Michelin Commander II. I didn't know it was "catalytic converter". My bad...
tstorey823 is offline
post #162 of 208 (permalink) Old 08-09-2012, 09:13 PM
king_arthur1953's Avatar
Originally Posted by IsAnOzzie View Post
ALL cars here have a tyre plate fitted stating the size, pressure suitable for the vehicle ( a police officer can book you for incorrect tyre pressures, are we over governed or what
I am not sure that we are actually required to have tires on the rims here in Arkansas. Yes you may be over goverened in the land down under.
Pastor Ron
"A man's true character is determined by what he does when no one is looking."
Pastor "That Biker Church"
President North Arkansas HonorBound Motorcycle Ministries
President/Founder "Wounded Spirit Ministries Inc."
Patriot Guard Rider
USAF 1971-19752010 Voyager 1700 ABS
Kawasaki CB Radio, J&B Elite headset, Ray's Throttle Mod, Road Commander II, Sagebrush Whale Tail Tank Bib, Firestik NGP CB antenna, Firestick AM/FM antenna eliminator, Amsoil engine oil and coolant
king_arthur1953 is offline
post #163 of 208 (permalink) Old 12-11-2012, 07:02 PM
Just replaced the front with the commander 2!
Wow what difference, it handles a lot better. Feels lighter, less input to start a turn. I did a 30 mile ride. Very nice, smooth.
Only one think to get used too. At very low speed it seams top heavy or harder to stay balanced. But great after I get moving.
07 1600 Nomad
Patriot Guard Rider
spicermech is offline
post #164 of 208 (permalink) Old 12-12-2012, 12:19 PM
I, for one, have experienced the wobble with the Commander II tires on my 2009 Vulcan Nomad 1700. As long as I have a grip on the handlebars, no wobble. But, if I release my grip slightly for a few seconds, at any speed above 40, the front end will start to wobble quite aggressively. I have about 2000 miles on them so far. I never experienced the wobble with the stock Dunlop tires.
NMGoose is offline
post #165 of 208 (permalink) Old 12-13-2012, 12:37 PM
VagaBond661's Avatar
The service department at my dealership said the ABS might be affected with going with a bigger tire but he wasn't 100% sure.
VagaBond661 is offline
post #166 of 208 (permalink) Old 12-15-2012, 11:27 AM
Windburn Bill's Avatar
I wouldn't blame the wobble on the tire until eliminating the possibility that it wasn't installed right. After having a shop put a Commander 2 on the front I was experiencing bad wheel hop at highway speeds. Took it to a friend with a tire changer set up. He broke it down and found water inside the tire. A LOT of water. Don't know how the kid at the tire shop got water in it but I don't do business there anymore.
Got tired of wearing out a rear tire every 10 K/10 months so I thought I would try a set of the Micheline Com 2's. Haven't reached the 10K mark so I don't know about longevity yet but I'm so impressed with the way they grip when blasting through the twisties and the smooth ride that I'll probably buy another set when these wear out. BTW...no problem fitting a 180/65-16 on the back of my '05 Vulcan 1600 Classic. About 1/4 inch clearance between the tire and swing arm, lowered the rear 1/8 inch, speedometer is 3mph off now instead of the factory 5.
'05 1600 Classic. Black...the fastest color.
Harley Street Glide 18" front wheel
Lowered Using Honda shocks
Barons PB's, Flanders bars
Cobra True Duals
Hypercharger
Dobeck TFI
Mutazu HL hardbags
One off drivers back rest
Windburn Bill is offline
post #167 of 208 (permalink) Old 12-15-2012, 11:32 AM
OverHillAndDale's Avatar
I put the Michelin Commander II on my Voyager last week. 130/90 B16 in front, 180/65 B16 on the rear. No problems with fit. I only got about 5000 miles off my 1st two rear tires (Bridgestone then Dunlop), so I'm looking forward to improved mileage on these.
Dale
2010 Vulcan Voyager /Ooops - I totaled it!/
OverHillAndDale is offline
post #168 of 208 (permalink) Old 12-15-2012, 11:35 AM
LOL! Now thats funny right there! As Jeff Foxworthy said "they prefer you put your boat on a trailer before dragging it home from the lake" too!
Cobra True Duals
Hypercharger
Dobeck TFI
Mutazu HL hardbags
post #169 of 208 (permalink) Old 12-15-2012, 11:43 AM
Had the same experience you had with the OEM Stones and Dunlops. Had a Dunlop E3 front for a while. Couldn't get that tire off soon enough. Roughest riding tire I ever bought. Felt every little rough spot in the road and the sidewalls started to Spider web after only 4K. Hated the E3. Maybe I just got a bad one but between that and all the reports of the Dunlop H402 coming apart I'm done with Dunlops.
Cobra True Duals
Hypercharger
Dobeck TFI
Mutazu HL hardbags
post #170 of 208 (permalink) Old 12-15-2012, 11:44 AM
IL Vaquero's Avatar
Hey guys I had put commII on front and back of my vaquero and had front end wobble from the start. Took to dealer and rep said wrong size back tire I said adj head bearings rep said normal wear and tear mind you this was at 6400miles. kaw would do nothing about it because back tire size I just got my vaq back from shop that installed tires because dealer would not install different size rear tire. Anyway new tapered head bearings and wheel bearings and no more wobble. Handles sooooo much better so I would say if they wobble adj head bearings or go with tapered one seems better to me . If this is all messed up I feel at work thur and craked 4 ribs and i'm on pain killers THank You Doc.
Only a motorcycle rider knows why a dog sticks he head out the car window. Enjoy life.
IL Vaquero is offline
