Steel and aluminum don't mix well and they seize. You need to "crack" them first and soak with penetrating oil. Soak for a while and take a brass punch/hammer and whack the bolts to try and crack them before loosening. Use anti-seize when you put them back on.
Napom and I changed his tires a couple of weeks ago. The rear caliper bolts were seized on his. With a bolt extractor tool (has teeth like a screw extractor that cut into the bolt head and grip it) and my big breaker bar, we got one loose. It took every ounce of strength that I had to get that one. We couldn't get the other one loose and chewed the head all up. He took it to the local Kawi dealer (Mountain Motorsports in Marietta) and they had some tool that they managed to break it loose with.
I really doubt the front wheel has ever been off the bike. Had only 3k miles on the bike when I bought it 6 months ago. I have pretty much destroyed the heads on these bolts trying to free them. Gave up for now. The tire has a few miles left on it so gonna get some penetrating oil and those bolt extractors and try again in about a week. Thanks for the advice.
(CAREFULLY)....Apply some heat to the (CAREFULLY) area round the bolts (CAREFULLY) and that should help free them (CAREFULLY). I think you can pick out the key word. If the heads are mucked up then you might need a bolt extractor. I had the same problem removing a rotor a while back. (CAREFULLY) applying heat to the area around the bolts did the trick and they came right out. But remember the key word. May have to drill the heads a bit to get the extractor started. :grin2:
I use my cordless 1/2 inch impact driver. Never had a problem with the caliper bolts but I have on lower shock tube bolts taking shocks apart. Rebuilt the shocks on one of my Yamaha's a few months ago. That plunger tube stem bolt on the bottom can be a bear. Usually sounds like you snapped it when it breaks loose.
The heads of the bolt do not have very large flats on them in the first place, they use a thread locker on these bolts also. Use a 6 point socket only and a longer ratchet or breaker bar. Do not jump on it but put steady even pressure on the bar. They will break free with out heat just takes work. I tried pulling mine when i bought my bike last year with 10k miles, front was probably never off the bike, and messed up the heads. I ordered new ones and it all good now.
Has anyone used different bolts for these? I have gotten them off but they are so bad not going to reuse them. Tried ordering new ones but every web site I found them say back ordered.
Do you have a kawi dealer close by? Had to replace oil pan washers and bolts called them after searching,they had plenty and were cheap,
you would think these are stock items:smile2:
If they were open today I would call them. Just wanted to have them ready for when I get my tire back Wednesday. Thought maybe I could get similar bolts somewhere else.
Related Threads
Kawasaki Vulcan Forum
712.7K posts
67.8K members
Since 2008
