problem with the voyager cooling system. - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 22 (permalink) Old 07-31-2011, 07:37 AM Thread Starter
justinmccurdy25's Avatar
i took the side cover where the sight glass is for the coolant overfill tank is and noticed in the bottom of the tank was a bunch of black particles floating around. i then said i need to find out what the hell that is so i flushed out my antifreeze and oh my god!! all kinds of black 1 inch long strips of paint was coming out. i noticed it was from the thermostat housing cover. the part that the radiator cap sets on. the inside of this frickin thing was peeling paint.WHAT THE FU%# WOULD YOU MAKE A DEVICE THAT HOLDS ANTIFREEZE, STRIP PAINT. SO, i flushed and flushed as much as i could out with distilled water. i got it so no more particles where coming out of the system, but that's not counting for all the nooks and crannies in that thing, especially the mechanical seal. just everyone make sure you dont have black particles floating around at the bottom of your reserve antifreeze tanks
2010 Vulcan voyager 1700
cobra tri ovals
cobra F.I.2000r
I-POD adapter
justinmccurdy25 is offline
post #2 of 22 (permalink) Old 07-31-2011, 08:54 AM
BrucerZX14's Avatar
This is the second owner I've read about the black flakes in the cooling system. I guess I need to flush mine and do the coolant fix that RACNRAY has mentioned. Thx.
2010 Voyager
Roaring Twinz Air Kit
Thunder Manufacturing dress-up plate
VN1500 kickstand
Chrome bling on passenger floorboards
Rockford Fosgate Amplifer
Polk Audio/Kicker speakers
Kawasaki CB radio
Rear speaker kit
Vance & Hines Twin Slash slip-ons
Power Commander V
Portable XM radio thru AUX
Marvellas trailer hitch
Lower bag rails
Kuryakyn Tour-tech cruise peg mounts
Kuryakyn black ISO grips w/bar-end weight & red trim
BrucerZX14 is offline
post #3 of 22 (permalink) Old 07-31-2011, 11:08 AM Thread Starter
Originally Posted by BrucerZX14 View Post
This is the second owner I've read about the black flakes in the cooling system. I guess I need to flush mine and do the clooant fix that RACNRAY has mentioned. Thx.
oh really, do you remember who it was? i just took the bike out and on the highway it seems to run a little cooler, but when i got home, i let it idle to see if the fan would kick off and the temp would just hover over that mark past half, it used to get low enough to shut the fan off..... oh oooo
cobra tri ovals
cobra F.I.2000r
I-POD adapter
post #4 of 22 (permalink) Old 07-31-2011, 11:27 AM
BrucerZX14's Avatar
3rd post this page of this thread: Cooling system help for the Big V
2010 Voyager
VN1500 kickstand
Kawasaki CB radio
Rear speaker kit
Power Commander V
Lower bag rails
post #5 of 22 (permalink) Old 07-31-2011, 12:31 PM
davidsheek's Avatar
I just changed out the coolant last weekend in accordance with RACNRAY and didn't have any flakes in the system but had small black grains in reservoir. Sadly I didn't see any drop in temp.
davidsheek is offline
post #6 of 22 (permalink) Old 07-31-2011, 12:38 PM Thread Starter
hers what those flakes look like. they are the same consistency as burnt ash. light and flaky and break apart when you touch them. these are dry ones though. man i hope they dont clog up the radiator or worse, the water jackets.
cobra tri ovals
cobra F.I.2000r
I-POD adapter
post #7 of 22 (permalink) Old 07-31-2011, 01:03 PM Thread Starter
flake ash is the consistency of this and breaks apart when touched, these are dried up.
cobra tri ovals
cobra F.I.2000r
I-POD adapter
post #8 of 22 (permalink) Old 07-31-2011, 05:58 PM
wbilotta's Avatar
I wonder if this debris is blocking our radiators ?
wbilotta is offline
post #9 of 22 (permalink) Old 07-31-2011, 07:13 PM
Top K's Avatar
Curious how many miles you have on your ride? Mine only has six grand, but if at least two have had this issue, I may be checking my coolant early.
'09 Kawasaki Voyager ABS
USMC 77-99
PGR
Band of Brothers USMC MRC
Top K is offline
post #10 of 22 (permalink) Old 08-01-2011, 07:08 AM Thread Starter
I have 9000 on mine, the only reason I flushed and changed is because I seen these in the overflow tank. Been doing research, seems that alot of motorcycles and cars have this paint peeling from inside, mine seems to be running the same, if not cooler then it was.
cobra tri ovals
cobra F.I.2000r
I-POD adapter
