Problems with new 2007 500 - Page 2 - Kawasaki Vulcan Forum : Vulcan Forums
post #11 of 40 (permalink) Old 12-08-2012, 03:39 PM
bikerbill's Avatar
Year/Make/Model: 1997 Vulcan LTD
Displacement/CC's: 500
Color: Black
Originally Posted by red_leg View Post
Always run premium in it. 91 or higher. It will work with lower octanes but you'll be setting yourself up for an early rebuild.
Would you consider rebuilding at 108,000 miles an 'early rebuild'? I run 86AKI exclusively and tend to disagree with that assessment.
'Biker' Bill
'97 EN500LTD 'Hidalgo' 189,000+ miles so far
'98 EN500LTD 'Son of Hidalgo' 18,000 miles so far
VROC #3833 IronButt #6024
Levelland, TX
bikerbill is online now
post #12 of 40 (permalink) Old 12-08-2012, 04:27 PM
That engine should pull clean and hard from idle to red line in any gear and if it will not, something is wrong. Having to run at or near red line in order for it to move under its own power is no good and a safety hazard.
Pull fuel line off at carb, put end in a pop bottle, start engine and fuel should freely flow.
Check for vacuum leaks around carb boots.
If no success with above, carbs will have to come off for a teardown, clean and inspection...no getting around it.
sfair is offline
post #13 of 40 (permalink) Old 12-09-2012, 12:58 AM Thread Starter
There's some acceleration at lower speeds in the higher gears, but not a lot, and second in particular seems jerky below 20. Though I drive my car with a lead foot, so maybe I'm expecting a bit much. Everything I found about this bike said to rev it, and I'm not going much higher than the maximum speeds for the break-in period, I'm certainly not holding the throttle wide open or anything. First seems slow at first, then takes off when it hits about 12, second seems slow and jerky till it hits 25, then it takes off. Even before I started having problems I was starting to wonder if the idle speed was too low. It would take at least 2 minutes of idling with the choke on full for it to stay running when I moved the choke to half, then on half for a minute or so to stay running with the choke off in 50-60 degree weather. After warming up idle still seemed a bit weak, and I'd have to give it some throttle for it to move much in the friction zone. Now with the higher idle speed and premium gas it takes about 30 seconds on full choke to warm up, and there's actually some pull in the friction zone. I am a bit worried that the idle speed might be a bit high though, how do you tell if the idle speed is set right without a tach?
FCastle is offline
post #14 of 40 (permalink) Old 12-09-2012, 06:43 AM
Blaine's Avatar
It should be about 1200 RPM.About the same as the fast idle on your car.
If at first you do succeed,try not to look surprised.
Blaine is online now
post #15 of 40 (permalink) Old 12-09-2012, 09:57 AM
High idle speed is just semi-covering up a problem.
Premium gas will fix nothing.
You are going to have to get down and dirty with a little troubleshooting.
See post #12 to start with the basic and easy first two steps.
As an add, gas should not dribble out in step number 1, maybe with the exception of what is in the fuel line, when the engine is not running.
Post back with results and any questions.
sfair is offline
post #16 of 40 (permalink) Old 12-09-2012, 04:09 PM Thread Starter
Originally Posted by Blaine View Post
Have you tried running it with the fuel cap open to make sure you don't have a vacuum lock.??
Tried, doesn't seem to make a difference. I sat in my driveway revving it a few times, after a minute it started to rev without the hesitation, though it still seems to be running a bit rough. However, now when I close the throttle it takes 2-5 seconds to return to idle. The throttle free play and cables seem to be okay, and the throttle snaps closed.
FCastle is offline
post #17 of 40 (permalink) Old 12-09-2012, 06:26 PM
However, now when I close the throttle it takes 2-5 seconds to return to idle. .
See post number 12, second diagnostic test.
Driveway revving will tell you nothing.
Post back with any questions.
sfair is offline
post #18 of 40 (permalink) Old 12-09-2012, 08:04 PM
Year/Make/Model: 2001 Kawasaki Vulcan 1500L Nomad FI
Displacement/CC's: 1500cc
Color: Burgundy/silver
I'm going to say a plugged pilot jet from sitting before you bought it. The dealer more than likely blatently lied to you. Rest assured, stranger things have happened. Mine had a similar problem with "hesitating" when you open the throttle and "hanging high" after it snapped back (see my previous started threads). Except mine had backfiring and power loss too. So maybe you caught this before it got TOO bad.
Agree with BikerBill on the octane. Manual says 87 octane, put 87 in it. Any more is a waste of money.
Also, your fuel economy should only be that low if you accelerate like that EVERY TIME you enter a main road from a side road. Just like a four wheeler, if you keep the RPMs down, the fuel economy will go up.
Zim_the_Giant is offline
post #19 of 40 (permalink) Old 12-09-2012, 09:04 PM
Blaine's Avatar
Agreed."hanging idle" indicates a lean mixture or plugged pilot jets..
post #20 of 40 (permalink) Old 12-10-2012, 09:34 AM
Hanging idle means vacuum leak. The idle hangs because it is getting air from elsewhere besides the carb.
sfair is offline
