Lower seat- - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 20 (permalink) Old 12-06-2012, 08:59 AM Thread Starter
Lower seat-
Guys, I would like to lower the seat on my 1990 Vulcan 500 so after reading posts bought a set of shocks off a Suizuki 650, 1996 model( according to the seller) off E Bay- no help, same size as the ones on the bike, 12 inches. Question- what is the best shock to get , also what size are the shocks on a 96 Savage? Or other options?
Thanks,OS
PS- shocks for sale cheap-
old sinner is offline
post #2 of 20 (permalink) Old 12-06-2012, 09:20 AM
Blaine's Avatar
Thanks,OS
The Savage (S40) shocks should be 10 1/2".
If at first you do succeed,try not to look surprised.
Blaine is offline
post #3 of 20 (permalink) Old 12-06-2012, 09:43 AM Thread Starter
Thanks-
Blaine, looks like I got E Screwed-
OS
post #4 of 20 (permalink) Old 12-06-2012, 05:25 PM
I installed this on my 500, but you have to remove the metal bushings and file to size (the width) they are wider than the mounting U bracket.
http://www.ebay.com/itm/180827864814...S:3160&vxp=mtr
juanvm7 is offline
post #5 of 20 (permalink) Old 12-06-2012, 06:46 PM
Blaine's Avatar
Yep.I believe they are 11" in length.
Blaine is offline
post #6 of 20 (permalink) Old 12-07-2012, 05:48 AM
Description
Aftermarket, Good quality!
Eye to eye of center to center: 270mm (10 5/8"); Bushing: 14mmand 10mm;
Honda Rebel CA250 1996-2011
Honda Rebel CMX250 1996-2011
Honda Rebel CMX250C
juanvm7 is offline
post #7 of 20 (permalink) Old 12-07-2012, 11:46 AM Thread Starter
Lowering shocks-
Read the post about making a jig for disssembling shocks, thought I would try to cut down the shocks I got from E Bay, any tips on cutting springs? Maximun amount to cut off, shape ends etc.?
Thanks, OS
post #8 of 20 (permalink) Old 12-08-2012, 07:48 AM Thread Starter
Help cutting springs-
Any tips about cutting the shock springs, never done this, max. amount to cut?
OS
post #9 of 20 (permalink) Old 12-08-2012, 11:53 AM
coolmesser's Avatar
personally I would call Hagon Shocks USA in Cali. They make some that are 255mm long and they can match whatever bushing size you need.
http://www.hagonshocksusa.com/HagShocks.htm
All custom Vulcan 500 Long Chopper
with 10" over tubes and King & Queen seat
coolmesser is offline
post #10 of 20 (permalink) Old 12-08-2012, 02:20 PM
Blaine's Avatar
Thanks, OS
When I cut mine,I just used a cut off wheel on my grinder.I cut 1 1/2" coils out of mine.But I cut out a half coil at a time & reassembled to check for height.I ground the tip of the coil flat so there is no sharp edges to sit inside upper cap.
Blaine is offline
