Blinker relay- - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 8 (permalink) Old 11-14-2012, 10:04 PM Thread Starter
Blinker relay-
Turn signal were not flashing on my old 90 vulcan so after some reading on the net I shorted the connector after removing the relay and the lights came on indicating a bad relay. I popped off the rubber cover and found the capacitor shorted, unable to find the value of the cap., number is 5480, code 9yb.
Anybody know this value?
Thanks, old sinner
old sinner is offline
post #2 of 8 (permalink) Old 11-14-2012, 10:28 PM
Blaine's Avatar
Thanks, old sinner
Just so you know.You can use a automotive flasher.When people switch to led's they have to use a electronic flasher so that the signals will flash properly.
If at first you do succeed,try not to look surprised.
Blaine is online now
post #3 of 8 (permalink) Old 11-17-2012, 12:16 PM
If it is the signal flasher that you are reading, it should be shorted.
sfair is offline
post #4 of 8 (permalink) Old 11-18-2012, 11:05 PM Thread Starter
Nah, reading the cap out of circuit-
os
post #5 of 8 (permalink) Old 11-19-2012, 11:31 PM
os
????? What capacitor???? There is no capacitor that I know of.
sfair is offline
post #6 of 8 (permalink) Old 11-20-2012, 12:11 AM
coolmesser's Avatar
when you put LED's on both front and back then you need DIODES on the inputs to the indicator light ... one diode on each input and those spliced together into one post on the indicator light with the other post going to ground.
Kuryakyn makes a kit with the diodes already connected to wires for you.
It's their item # 4709.
All custom Vulcan 500 Long Chopper
with 10" over tubes and King & Queen seat
coolmesser is offline
post #7 of 8 (permalink) Old 11-20-2012, 08:01 AM Thread Starter
This is a stock bike, I removed the flasher from the rubber case and the relay has a capacitor and a 150 ohm resistor, I think is is the timing circuit. The cap tested shorted (removed from circuit). I have put a 1000 mfd., 20 volt cap in but the lights flash too fast. Would like to know value of the cap, 5840, 9yb to get the right flasher speed.
Thanks for your input , os
post #8 of 8 (permalink) Old 11-20-2012, 09:49 AM
Ooops, looks like you have a non-oem flasher there.
Doubling the capacitor value should "about" halve the flash speed.
Or see post #2.
sfair is offline
