Smog Block Off plates - Blocking the hose? - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 10 (permalink) Old 11-07-2012, 03:01 PM Thread Starter
So I did the smog block off plate mod on one bike and it was easy, I just put a cover on the hose that goes from the air box to the airflow switching valve.
But on this bike it's different. I'm not sure how to block it off. The hose just goes into the air box. I guess I could just tape it off, but I'd be worried about the tape failing and being pulled into the engine unfiltered.
Any suggestions?
xantonin is offline
post #2 of 10 (permalink) Old 11-07-2012, 05:37 PM
Blaine's Avatar
This kit has the plates & plugs necessary for removal of the PAR system.
http://lamponedesigns.com/product_pa...101/index.html
If at first you do succeed,try not to look surprised.
Blaine is offline
post #3 of 10 (permalink) Old 11-07-2012, 05:42 PM Thread Starter
Damn, it does. And it's a much better price than I paid for my eBay one too. Well, too late now though. Can anyone identify what they used? Maybe I can pick it up at Home Depot.
xantonin is offline
post #4 of 10 (permalink) Old 11-09-2012, 02:04 PM Thread Starter
The owner of that site is awsome! I asked if they could send me just the grommet and they are doing it plus shipping. I gave them a tip.
Thanks for the link.
xantonin is offline
post #5 of 10 (permalink) Old 11-09-2012, 04:09 PM
Blaine's Avatar
No problem.Glad I could help!!
Blaine is offline
post #6 of 10 (permalink) Old 11-09-2012, 07:35 PM
Link to this mod? benefits?
4DGS is offline
post #7 of 10 (permalink) Old 11-09-2012, 07:46 PM
dwhit's Avatar
What does this mod do?
dwhit is offline
post #8 of 10 (permalink) Old 11-09-2012, 08:33 PM
Blaine's Avatar
Cleans up the top of the engine by removing all the unneeded smog hoses.With all the hoses removed it also makes it much easier to do a valve adjustments.
Blaine is offline
post #9 of 10 (permalink) Old 12-22-2012, 06:52 PM
jimmyswagger23's Avatar
I purchased this kit with the gaskets. PERFECT!! Took longer to get the tank off than to remove this system. The best thing is no more popping on deceleration!!!!!! Also cleans up the top of the engine so you can see through to the other side, Highly recommended.
2000 EN500, CUSTOM PAINT
BILLET WAVE HEADLIGHT
INTEGRATED LED REAR LAMP
BILLET PLATE FRAME W/LED'S & CUSTOM BRACKET
LED REAR FENDER MOUNT RUN/TURN SIGNALS
SUZUKI SAVAGE SHOCKS
HARLEY DYNA MUFFLERS
DE-REFLECTOR'D
DE-CAL'D, PAIR REMOVED
FORK MOUNT LED RUN/TURN SIGNALS
32" Y BAR W/6" RISE
KURYAKYN ISOGRIPS W/BAR ENDS & THROTTLE BOSS
KURYAKYN BLIND SPOT TURN SIGNAL MIRRORS
KURYAKYN WIDE GRIP LEVERS
KURYAKYN ISOPEGS
SHAVED STOCK SEAT PAN W/CUSTOM MOUNTS
VORTEX 17T FRONT SPROCKET
jimmyswagger23 is offline
post #10 of 10 (permalink) Old 12-28-2012, 09:04 AM Thread Starter
This is a very common mod on sports bikes but the benefits are the same. Smoother deceleration ati no more popping noise.
In my R6, it helps with giving you a more accurate fuel/air ratio which can be used to tune the bike more.
xantonin is offline
