Drag Bars - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 9 (permalink) Old 10-30-2012, 06:08 PM Thread Starter
nitroeagle's Avatar
Drag Bars
Anyone running drag bars out there? The stock bars just aren't comfortable for me. I had them on my cb650 & spirit750. I'm thinking a 30 inch wide bar & 3 1/2 inch risers with 1 inch of pull back.
nitroeagle is offline
post #2 of 9 (permalink) Old 10-30-2012, 10:49 PM
I just ordered some off another member.
They're 32" bars with I believe 3" or 3.5" risers. Can't recall the pull back right now.
I'll let you know how they go though.
4DGS is offline
post #3 of 9 (permalink) Old 10-31-2012, 09:22 AM Thread Starter
nitroeagle's Avatar
Thanks 4dgs. That would be great. I've been looking around. Tool some measurements last night. I think I might have to go with 5 inch risers to clear the tank, like these
post #4 of 9 (permalink) Old 10-31-2012, 11:48 AM
Yea the bars I picked up came with some risers for a pretty solid price, not sure if they will be enough to clear the tank though as the bars mount pretty low on these bikes.
4DGS is offline
post #5 of 9 (permalink) Old 11-02-2012, 03:35 PM
Meanstreak 1600 bars. Those have like a 5" rise, 3" pullback. Solid one piece construction basically w welded risers, spacers on risers is 3.5" as well
derekd403 is offline
post #6 of 9 (permalink) Old 11-11-2012, 10:53 PM
Sportster setup
I used a riser and bars off of a harley sportster. the riser was a little tricky since i had to use coupling nuts to make the riser fit, but it looks great and it feels much more comfortable. Plus It's as high as it will go without having to extend the cables
rludingt is offline
post #7 of 9 (permalink) Old 11-12-2012, 10:44 AM Thread Starter
nitroeagle's Avatar
rludingt, do you have a pic of the set up? I'm guessing you don't have any clearance issues with the tank. Thanks
post #8 of 9 (permalink) Old 11-14-2012, 02:29 PM
Here the Pics
I have no clearance issues with the tank at all
ID:	14220   Click image for larger version
rludingt is offline
post #9 of 9 (permalink) Old 11-14-2012, 04:29 PM Thread Starter
nitroeagle's Avatar
Thanks for the pics. Looks good. I think I should be good then. Bars are here, waiting on the risers.
