Need to replace my chain... should I get oem endless or aftermarket master link? - Page 3 - Kawasaki Vulcan Forum : Vulcan Forums
 1Likes
post #21 of 29 (permalink) Old 10-21-2011, 10:09 PM
whoaru99's Avatar
Originally Posted by Blaine View Post
Yep,same as replacing the belt on the older Vulcan or 454.Not a big job,about 2 hours.
In your garage, maybe.
whoaru99 is offline
post #22 of 29 (permalink) Old 10-21-2011, 11:12 PM
Blaine's Avatar
No.Actually out in the yard with a small jack under the center stand.
If at first you do succeed,try not to look surprised.
Blaine is offline
post #23 of 29 (permalink) Old 12-06-2012, 11:15 PM
I am wanting to get a new chain and reading all the posts has my head spinning,,
I have an oem chain on my 500, and it has the o-rings, I don't know what an X- ring is.. I am a retired carpenter and really appreciate the help I have received here since getting my bike in March 2012.. I have 7,500 miles on the bike ,,a friend says I need a new chain ,, but from what I read here,, I should be good to 20, 25 ,000 miles,, any replies are truly welcome __thank You _ Al Vulcan
PS, What do you reccommend for cleaning and for lubricating ?
Al Vulcan is offline
post #24 of 29 (permalink) Old 12-07-2012, 12:05 AM
Mambo Dave's Avatar
You may need a new chain, but it surely can't be due to chain stretch by now.
Old bikes that aren't used enough, or aren't lubed enough, can end up with stiff chain links that may eventually ruin a long-distance ride. You need to ask your friend why he thinks you need a new chain, then either trust him, double check that with someone else, or write it up here for people to respond to.
X-rings are just o-rings with molded surfaces that can better protect the lube inside the links. They really shouldn't cost more (unless they have a much higher tensile strength for higher horsepower bikes), but they generally do.
vid
big grips, 19-42 tooth sprockets
rusty handlebars, rusty pegs, rusty mirrors
wrapped Cobra exhaust, K&N Air Filter
Mambo Dave is offline
post #25 of 29 (permalink) Old 12-07-2012, 12:08 AM
rick's Avatar
05 800, I replace my chain and sprockets at the same time every year at the end of winter. I average about 20,000 a year. X-ring chain and clip style master link. My 1st chain went 38,000, but also had several rollers missing when I changed it, was past due! Never had a problem with them. Avoid aluminum sprockets, get steel.
2005 800 classic
2012 Voyager ABS
rick is offline
post #26 of 29 (permalink) Old 12-12-2012, 10:27 PM
GeorgiaRider's Avatar
31K miles on my original chain. Clean/lube every 400 miles. Still in great shape.
GeorgiaRider
2006 Vulcan 500
Saddlemen Cruis'n Large Slant Saddlebags
Kuryakyan Foot Peg Extenders and Pegs
Kuryakyan Iso-Grips and Throttle Boss
Memphis Shades Alley Cat Windshield
Powersports Mini-Tachometer
Kawasaki Luggage Rack
Airhawk cushion
Marlin's Clock
GeorgiaRider is offline
post #27 of 29 (permalink) Old 12-15-2012, 04:28 PM
Ok, I'v read it all a couple times ,,but I'm still uncertain about which brand to buy..I dont want to loose the chain at any speed.
Maybe just a little more help ..PLEASE"" Thanks
post #28 of 29 (permalink) Old 12-16-2012, 05:47 AM
I've had such good luck with the original OEM chain I may order another one unless someone makes an even better one. 31K miles on the original chain...
GeorgiaRider
2006 Vulcan 500
Airhawk cushion
Marlin's Clock
post #29 of 29 (permalink) Old 10-29-2015, 06:54 PM
bikerbill's Avatar
Year/Make/Model: 1997 Vulcan LTD
Displacement/CC's: 500
Color: Black
Regarding chain life:
The previous chain that was on Hidalgo was a Tsubaki Omega X-ring chain and I pulled it off after 43,000 miles. I went back with a Tsubaki Sigma X-ring chain.
Cleaning/lubricating is generally handled by a ScootOiler. Until last week I hadn't done a full chain maintenance in a *long* time. And that is because I went down a dirt road for about 15 miles when my GPS decided that it was a shorter way and the entire back of Hidalgo was crusted in dirt/dust.
Mambo Dave likes this.
'Biker' Bill
'97 EN500LTD 'Hidalgo' 189,000+ miles so far
'98 EN500LTD 'Sioux' 18,000 miles so far
VROC #3833 IronButt #6024
Levelland, TX
bikerbill is online now
