I have a 2001 Kawasaki Vulcan en500/ While doing some detailing I broke the ignition switch. I need the bike to run to get it moved to a friend's garage. Can anyone tell me the wiring diagram? I have blue, white, grey, red and brown.
Thanks.
I have a 2001 Kawasaki Vulcan en500/ While doing some detailing i broke the ignition switch. I need the bike to run to get it moved to a friends garage. Can anyone tell me the wire diagram. I have blue, white, grey, red and brown. Thanks.
Brown is for things that need to be energized, like the radiator fan, etc.
Gray is for the ignition/ignitors themselves.
Connecting white, brown and gray should get you going. Add blue for lights.
Thank you for the info Paco. Let me go back out and try. Ok did that. It seems to work like you said. Brown, white and grey. Tie Blue and red for tail light. But still not starting. It ran when the switch was on but i didnt ride it because of expired tags. When i went to move it found rear brake locked up and when got loose is when i dropped the bike and broke key switch. Am wondering now if i shorted something in the mean time to try to start. guess i need to pull tank and see if getting any fire to plugs.
I already tried that combo. Yes it turns over. The console light, headlight and front signals come on with Grey, Brown and white. Also when the bike is in neutral the neutral light comes on. I do not think i am getting any spark. Will have to check tomm when i get home from work. Riding the bus again.
How long was it sitting that the rear brake seized?If your getting spark to the plugs,(I suspect that you are).You will need to check to see if you are getting fuel.
Get a 100 ohm 1/2 watt resistor, lift the grey wire from the twist, solder one end of resistor to grey wire, twist other end of resistor together with white and brown. I will not explain what is going on here for obvious reasons.
Hey I'm having the same thing with my 2002 kawasaki Vulcan 800 B I put the red and blue wire connecting it to the battery it turns over but no spark I lost my keys and don't have 135 bucks to spend for a new one and not really understanding what yiu mean on this post anyway you can explain
Thank you to all that helped. I am about to make my first official ride on my Vulcan in the Keys at night. It is star filled night and cool for here. The perfect weather. SFAIR> Special thanks to you. You are the man.
Will be posting pics of the bike and the rebuild soon to come. It is all because of you.
Hello 1 question i am rewiring my key switch & i have 6 post & you are showing 5 wires i a bit confused .I bought this Kawasaki 1600 mean streak that the wiring harness had melted most of the wires including the wires in the key housing that i could not tell what wire went where .So i bought a new wiring harness and i can only see this photo that shows 4 wire but not sure where the brown wire goes to .thank u for the help .
Ok I have a similar problem on my 1998 Kawasaki Vulcan 1500 so I thought I lost the key A buddy of mine drilled out the back of the ignition switch and then a day later we found the key in the yard ignition switch still turns on the brake light tail light headlight will not come on unless if I use like a jump wire from a hot wire and touch power to the headlight and remove it and you'll stay on and work properly problem is I'm not getting fired to my plugs could that have a possibility of why I'm not getting fired from drilling the back of the ignition switch
Is there away to send you a video of what's going on that's when I hit the start button it clicks at the fuel pump and at the fuse box and like I said I have to use a jump wire to kick my headlight on when I turn the key on but the tail light and the speedometer light ignition light all comes on but the headlight won't until I jump it and then I take the jump wire off and it still works but I'm not getting no spark to my plugs would that have to do with the ignition being drilled out where anything can turn the ignition
Headlight should not come on until start button is pressed. Then relay in relay panel pulls in. Drilling out the switch may have damaged the contacts. If you do not have the 6vdc on the gray wire going to the igniter, you will not have spark to the plugs.
With the ignition switch on, there is a red wire that supplies battery voltage to each ignition coil. Make sure you have voltage there. I assume bike was running prior to drilling out switch?
Bandit 101 I have power 12 volts to the black wires on top post of the coil but no power to the red?green wires on the bottom of the coils do i have them backwards ?
Yes it was running before drilling it out from losing the key and okay let me check volts to the coils how many volts should the coals be showing just by chance
Related Threads
Kawasaki Vulcan Forum
712.7K posts
67.8K members
Since 2008
