check those battery connections - Page 4 - Kawasaki Vulcan Forum : Vulcan Forums
post #31 of 48 (permalink) Old 09-20-2012, 08:56 PM
GeorgiaRider's Avatar
Yes. That was happening to me when I was a rookie and I couldn't figure out what it was. Finally narrowed it down to loose connections.
GeorgiaRider
2006 Vulcan 500
Saddlemen Cruis'n Large Slant Saddlebags
Kuryakyan Foot Peg Extenders and Pegs
Kuryakyan Iso-Grips and Throttle Boss
Memphis Shades Alley Cat Windshield
Powersports Mini-Tachometer
Kawasaki Luggage Rack
Airhawk cushion
Marlin's Clock
GeorgiaRider is offline
post #32 of 48 (permalink) Old 11-05-2012, 09:14 AM
Xtreme Volts AGM battery
I wondered if anyone has any experience, good or bad, with this AGM battery. It is one of the very few agm types I can find in the A2 size.
Thanks!
dthomso1 is offline
post #33 of 48 (permalink) Old 11-05-2012, 11:40 AM
Blaine's Avatar
[QUOTE=dthomso1;266395]I wondered if anyone has any experience, good or bad, with this AGM battery. It is one of the very few agm types I can find in the A2 size.
Thanks![/QUOTE
I have one in my 454.Great battery.Much better than the old style.No water level to check,no spilled acid to worry about,& no vent tube.
If at first you do succeed,try not to look surprised!
Blaine is offline
post #34 of 48 (permalink) Old 11-05-2012, 04:35 PM
Originally Posted by MN-Rider View Post
Sticky worthy?
For sure! This caused me more than few pains untill I took the battery out and saw what was what.
nitroburner is offline
post #35 of 48 (permalink) Old 04-21-2013, 10:16 AM
Recommendation for a maintenance free battery
Any recommendations for a maintenance free battery?
2005 Vulcan EN500 - Blue. "T'Lola"
Waterloo, Ontario, Canada
Msimon1960 is offline
post #36 of 48 (permalink) Old 06-01-2013, 10:21 PM
Awesome post. This just saved me a bunch of time and a headache of troubleshooting the problem. Great explanation and an easy fix.
Northbay_G_Men is offline
post #37 of 48 (permalink) Old 04-13-2014, 02:31 PM
I've encounter this problem yesterday aout in nowhere was able to fix it and return home safely, Cehck those battery connection and it appears to be working fine, just to add something I added a little pice of rubber to the end of the battery connection to avoid damaging the terminal and screw it with no problems .
thx for this post !!
Jels is offline
post #38 of 48 (permalink) Old 04-13-2014, 05:02 PM Thread Starter
peruano's Avatar
Thanks for saying thanks. Yes the battery terminals are a two layered affair and too many folks don't check out both layers and think they have solved the problem. I put a bit of Loctite on my terminal connector bolts. Tom
Tom, New Mexico. Just trying to have me some fun.
2006 Kawasaki VN500
2002 Yamaha TW200
peruano is offline
post #39 of 48 (permalink) Old 04-14-2014, 06:40 AM
Ditto on Loctite (blue for me)...
GeorgiaRider
2006 Vulcan 500
Airhawk cushion
Marlin's Clock
post #40 of 48 (permalink) Old 04-20-2014, 12:00 PM
Is the horizontal/vertical post screw thing only an issue with the stock battery? Before I bought this bike the previous owner installed an AGM battery. Before I go pull off the seat, should I expect this may still be an issue?
byproduct is offline
