Chain Tension - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 16 (permalink) Old 02-20-2011, 03:18 PM Thread Starter
Chain Tension
I have a 98 vulcan 500. Didn't come with a book. Ordered one but they are saying it won't be in for another two weeks. My chain has some serious slack so it needs adjusted before I go for another ride. But the weather is SO nice right now! Could some please do a quick write up on how to adjust my chain so I don't have to wait two weeks and miss out on this gorgeous weather?!?
Dyne79 is offline
post #2 of 16 (permalink) Old 02-20-2011, 03:35 PM
bikerbill's Avatar
Year/Make/Model: 1997 Vulcan LTD
Displacement/CC's: 500
Color: Black
Chain 'slack' is 1" - 1 1/4". (25-35mm) I measure at the bottom for easy access to the chain.
I adjust the chain on my 1997 this way:
Rest the machine on its sidestand. Put transmission in Neutral.
Loosen the torque arm nut. Save cotter pin. If cotter pin is too damaged to reuse replace it!
Loosen the axle nut. Save cotter pin. If cotter pin is too damaged to reuse replace it!
Loosen the jam nuts on the chain adjusters on each side
Tighten the adjuster on the left side one 'flat' at a time, counting the 'flats', until the chain is at the proper tension.
Tighten the nut on the right side adjuster the number of 'flats' you counted on the left side.
Tighten the axle bolt. Reinsert cotter pin.
Tighten adjuster jam nuts.
Tighten torque arm nut. Reinsert cotter pin.
Go riding.
'Biker' Bill
'97 EN500LTD 'Hidalgo' 187,000+ miles so far
'98 EN500LTD 'Son of Hidalgo' 17,000 miles so far
VROC #3833 IronButt #6024
Levelland, TX
Last edited by bikerbill; 03-14-2011 at 01:10 AM. Reason: Added lines to include torque arm nut
bikerbill is offline
post #3 of 16 (permalink) Old 02-20-2011, 03:39 PM Thread Starter
So the chain should move down about an inch from its resting position and up about an inch from resting?
Dyne79 is offline
post #4 of 16 (permalink) Old 02-20-2011, 03:46 PM
bikerbill's Avatar
Color: Black
The measurement is for total distance from top of travel to bottom of travel.
'Biker' Bill
Levelland, TX
post #5 of 16 (permalink) Old 02-20-2011, 03:51 PM Thread Starter
Woo ok. So roughly half an inch in either direction. Yeah I am WAY off then
Dyne79 is offline
post #6 of 16 (permalink) Old 02-20-2011, 03:53 PM Thread Starter
Does the axle bolt have any specific torque setting?
Dyne79 is offline
post #7 of 16 (permalink) Old 02-20-2011, 04:03 PM
bikerbill's Avatar
Color: Black
Spec for the axle nut is 65 ft-lb then continue to the next cotter pin hole (there are two sets of holes 90 deg to each other on the axle).
'Biker' Bill
Levelland, TX
post #8 of 16 (permalink) Old 02-20-2011, 07:40 PM Thread Starter
Got it done in no time and got a nice ride in. Sun may be shining but its pretty cold at 70 mph! Thanks man!
Dyne79 is offline
post #9 of 16 (permalink) Old 02-20-2011, 08:43 PM
bikerbill's Avatar
Color: Black
You're welcome. It's windy out here (gusts to 30mph) so no pleasure riding today.
Ride safe.
'Biker' Bill
Levelland, TX
post #10 of 16 (permalink) Old 02-21-2011, 04:28 PM
Don't forget to lube the chain too.
Larry
1995 EN500
S/W Michigan
Larryb22 is offline
