what weight oil for 2009 vulcan 900 - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 14 (permalink) Old 06-17-2010, 05:56 PM Thread Starter
whats the best weight oil 10w40 or 10w50 , full syn? what brand ?
vulkurt is offline
post #2 of 14 (permalink) Old 06-17-2010, 06:01 PM
V Twin's Avatar
10-40 is the recommended in the manual. I once used a 20-50 and the bike became to noisy so went back after 1000 miles. I now run 15-40 and I wouldn't recommend anything thicker than that on a water cooled engine.
Gitty Up & Go!
V Twin is offline
post #3 of 14 (permalink) Old 06-17-2010, 09:16 PM
15w40 amsoil baby
2008 Candy Lime Green VN900C
Cut/DeBaffled OEM Pipes
Ram Air Mod
Lowered 2"
Saddlemen Seat
9" Apes
thehun is offline
post #4 of 14 (permalink) Old 06-17-2010, 09:33 PM
Pretzel's Avatar
I run 15w40 dino oil, as far as what brand... well, plenty of opinions/arguments/discussions out there, just watch out as some people get VERY angry.
LED Run/Turn/Brake
Vance and Hines Duals
Dobeck TFI
Vista throttle lock
Pretzel is offline
post #5 of 14 (permalink) Old 06-17-2010, 11:50 PM
V Twin's Avatar
Yup, there is two coments that will get some bikers really upset.
Oil & car tires on a bike.
Gitty Up & Go!
V Twin is offline
post #6 of 14 (permalink) Old 06-18-2010, 04:22 PM
bob900's Avatar
I agree dont run 20 50 as for i was also noticing the louder trans noise so back to a quiet running 10 40. Well not to quiet these bikes are just a little bit noisy with valves ticking away like crazy. But all good as this is what this engine sounds likel.
bob900 is offline
post #7 of 14 (permalink) Old 06-18-2010, 04:53 PM
oil
This subject came up on here a while back and there were some tense moments! LOL. I just did my first change myself after the 600 mile suggestion in the manual. What I took from the majority of the entries is that you shouldn't use synthetic for the first couple changes since it sticks more and won't drain out the metal shavings as much? So...I went with Valvoline 10-W-40 as in the manual and used the 2002 Infinity Filter for $6.00 from Napa as reccomended on here. Fit well, tons cheaper than the OEM and others. My dealer said I have to come in as he has the tool you need to get old filter off. I bought one at Napa for $5.00. Have to make sure the oil is CA listed on the bottle for the wet clutch. Not all car oils have that, the Valvoline I used said ATV on the label and was $5.00 per quart.
2009 Black Classic
Mustang Seat w/Backrest
Cobra Standard Backrest with Luggage Rack
Smoke Slipstreamer Windshield
Lindby Multibar Engine Guards
Homemade Lowers
Wally World Running Lights
Stebel Air Horn
Vista Cruise Control
Scootworks Front OD Pulley
Stage 2 Debaffle Stock Pipes
170/80/15 Pirelli Rear Tire
Kury Run/Turn/Brake module
gmer140 is offline
post #8 of 14 (permalink) Old 06-18-2010, 08:27 PM
The upper range in the engine spec book for 10W-40 is 104 F (40 C). There are times here in KC where that is exceeded. Not often but it happens. So I run 20W-50 Mobil 1 V-twin oil during the summer months and 10w-40 Mobil V-twin during the rest of the year. That's a quandry because there are times in winter where the bottom of 10w-40 isn't low enough. My bike is inside at nights but sits outside all day. Usually the temperatures raise above the lower limit before I leave work.
I haven't noticed any loud noises with the 20 w, in fact it's usually quiter. but it's extreme cases where the 10-40 is exceeded and the vast majority of bikers aren't going to be out riding in that junk where some of us just have the commute home.
This is just what I do. Nobody else has to do it, just because it's in the manual doesn't mean you need to do it. Heck, half the people have problem reading that thing for Octane ratings let alone a temp chart for oil.
MrClean is offline
post #9 of 14 (permalink) Old 06-18-2010, 08:38 PM
Shiloh's Avatar
The number of octane questions is impressive.
09 Vulcan 900 Custom - Traveller
09 FZ 6 - Lakota
Shiloh is offline
post #10 of 14 (permalink) Old 06-20-2010, 04:46 AM
azpostal's Avatar
I too am ready to attempt my first oil change. I just don't know about using 10w40. It was 105 here today!
azpostal is offline
