Aftermarket hand grip sticking - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 15 (permalink) Old 04-13-2010, 08:15 PM Thread Starter
I have an '09 VN900 custom SE, and I decided that it would look and feel much better if I installed aftermarket grips. I wanted to start with the throttle because I am a little scared to cut off the other grip. Turns out that it hits the bar-end and sticks. I have read on another thred that it was prob the bar-end. Well, thats all well and good, but how do I fix it?
Everlastingchub is offline
post #2 of 15 (permalink) Old 04-14-2010, 09:38 AM
Elimin8or23's Avatar
Send a message via AIM to Elimin8or23 Send a message via Yahoo to Elimin8or23 Send a message via Skype™ to Elimin8or23
not sure what aftermarket gris you bought, but I just recently installed the Kuryakyn ISO grips on my custom. (looks great) I had the same problem at first, but found moving the grip and clamp out about an 8th of an inch cleared up the problem for me. I also looked over the directions again and for sticking throttle grip, it recommends using a little grease. I used white lithium grease. Mine are VERY smooth now. no problems for the last couple weeks while riding.
Hope this helps.
Tony
Elimin8or23 is offline
post #3 of 15 (permalink) Old 04-14-2010, 03:43 PM
Grips
Seems a little odd. I just recently put some new grips on my 06 Classic LT, and the throttle slide completely encloses the bar end. I don't see how the grip could even make contact with the bar end. Are you sure it's not on the inside (towards the throttle cables) where it's binding? Like maybe the grip is making contact with the throttle housing? If that be the case just slip the grip down the throttle tube a bit away from the housing.
Ikindoit
2006 VN900 Classic LT
ikindoit is offline
post #4 of 15 (permalink) Old 04-14-2010, 08:47 PM Thread Starter
Well, the grips that I bought are (I believe) LA chopper hex grips; black... Very cool looking.
The throttle slide is completely enclosed by the horn/kill switch box. The thing is that the kill switch box has a little nub/ peg thing that slides in a hole in the handle bar, and this makes the box and the throttle grip sit correctly. I know that its binding up on the bar end because when I take the grip off I can see the scrape marks on the end of the handle bars.
I like the grease idea, but its scraping pretty bad. Was thinking of filing down the bar end a little then running with the grease idea... What do you guys think?
post #5 of 15 (permalink) Old 04-14-2010, 11:20 PM
I would use a nice lat file and take it slow. the lithium grease helps not only stay smooth, but it does not get as thick as most others in cold weather. It worked well for me.
post #6 of 15 (permalink) Old 04-15-2010, 10:09 AM
On your bike the chrome handle bar is longer than the throttle sleeve, so the grip is sticking to the exposed part of the chrome handlebar? The throttle sleeve should completely cover all of the handle bar under the grip, so the rubber grip is just making contact with the sleeve not the handle bar. If the above is true, you may have to get a new throttle sleeve.
Ikindoit
ikindoit is offline
post #7 of 15 (permalink) Old 06-21-2010, 01:32 PM
I have a 91 Vulcan 88 and put aftermarket grips on and it did exactly what you are describing. I replaced the throttle cables and the problem was fixed.
souls20042 is offline
post #8 of 15 (permalink) Old 06-21-2010, 06:15 PM
V Twin's Avatar
Send them back and get what most use. The most popular are the Kury's and I have a pair of the Fire & Still from kawa.
Gitty Up & Go!
V Twin is offline
post #9 of 15 (permalink) Old 11-27-2012, 11:11 AM
tedkawi's Avatar
Throttle sticking; have had to roll it back
09 Vulcan 900, changed to Kuryakyn ISO grips last year, changed to apes 3 mos. ago.
The other day, it was cold, took the bike out and the throttle sticks for the 1st time since owning the 9.
I hear a squeaking under the tank as I twist the throttle without starting the engine. How do I attack the problem? Thinking of WD40, oil penetrant or disassembling. Shd I start with raising the tank or doing the handlebar push pull controls?
Thanks.
tedkawi is offline
post #10 of 15 (permalink) Old 11-27-2012, 11:36 AM
bosco's Avatar
Thanks.
Sounds like your cables are in need of some lubricant. I would not use WD40 as it could do more harm than good (will damage rubber). Most shops (even bicycle shops) carry good cable lube than will run down the inside cable as you apply. I know there are kits for this as well, but if you are careful you can apply a drop at a time with no mess. I use a tri lube (purchased from my local bicycle shop) that has a nice applicator tube, makes for a clean application on the cables. Should help with our squeaking.
2010 900 Classic
bosco is offline
